RoboTask User's Guide
Keyword Index
Home page
Quick Start Guide
Features
Getting Started in the RoboTask Window
Create Tasks
Run Tasks
Edit Tasks
Customize RoboTask
Purchasing
License Agreement
Trademarks and Copyrights
Several practical recommendations
Using Variables in Tasks
Using Variables
System variables
Custom variables
Create a Variable
Add Variables to a Task
Running tasks simultaneously
Task synchronization
Using built-in Basic
Running RoboTask as an NT service
Installing and running
Using UNC names
Authentication parameters
Errors processing
Menus
Task > New
Task > Edit
Task > Delete
Task > Run
Task > Stop
Task > Duplicate
Task > Create Shortcut on Desktop
Task > Exit
Options > View Log
Options > View Toolbar
Options > Settings
Options > Variables
Tools > Enable Automation
Tools > Enable All Tasks in List
Tools > Disable All Tasks in List
Help > Help Topics
Help > Send Bug Report
Help > About
Actions
General
Run Program/Open Document
Print Document
Send Keystrokes
Log Off
Pause
SQL Query
Wait for process
Terminate Process
Comment
Dialogs
Show Message/Play Sound
Question Dialog
Open Dialog
Save Dialog
Browse for Folders
Browse for Computers
Input Box
Files and Folders
Copy/Move File
Rename File
Delete File
Write Text File
Search for Files
Change Folder
Create Folder
Rename Folder
Remove Folder
Synchronize Folders
Wait for file
Zip
Pack Files
Extract Files
Internet
Check for Email
Send Email
Download Files
Ping Host
FTP
FTP Log On
FTP Log Off
FTP Download
FTP Upload
FTP Rename File
FTP Delete File
FTP Change Folder
FTP Create Folder
FTP Remove Folder
FTP PWD
FTP Transfer Type
FTP Command
FTP File Loop
FTP Syncronization
Dial-Up
Dial Up/Hang Up
Check connection
Variables
Create Variable
Set Variable
Remove Variable
Increment Variable
Delimited variable
Task Commands
Enable Task
Disable Task
Start Task
Stop Task
Wait for Task
Loops and Flows
File Loop
Text Loop
Dataset Loop
Window loop
Simple Loop
While loop
End Loop
Break
Continue
If Then
Else
End If
Window
Window Command
Check for Window
Wait for Window
For Windows NT
Start Service
Stop Service
Lock Workstation
RoboTask Commands
Minimize RoboTask
Restore RoboTask
Exit RoboTask
Enable Automation
Disable Automation
Log Message
Clipboard
Cut
Copy
Paste
Clear Clipboard
Get text
Put Text
Mouse
Move to object
Click
Move
Registry
Add key
Delete Key
Rename Key
Read Value
Write Value
Delete value
Rename value
Export
Import
Network
Send Command
Send Network Message
Network Plugin settings
Email
POP3 Open
POP3 Close
POP3 Mail Loop
POP3 Download Email
POP3 Delete Email
POP3 Messages Count
Parse Email
Basic
Evaluate
Basic script
RoboTaskApp object
CD/DVD Writer
Write to disk
Erase Disk
Eject/Load CD Tray
Triggering Events
Scheduler
Hot Keys
Tray Icon
Cyclic
File Monitor
Dial-Up Connection Monitor
Window Watcher
On Time Changed
On Battery Power is Low
On Spooler Changed
On Device Changed
On Palette Changed
On Display Changed
On Log Off
On Idle
Listener
Other software
© 2004-2008 Neowise.com
