Keyword Index
Table of Contents
Home page
- A -
Actions
Add key
Add key
Break
Break
Browse for Computers
Browse for Folders
Browse for Folders
Change Folder
Change Folder
Check connection
Check connection
Check for E-mail
Check for Email
Check for Window
Check for Window
comments
Comment
Continue
Continue
Copy/Move File
Copy/Move File
Create Folder
Create Folder
Create Variable
Create Variable
Dataset Loop
Dataset Loop
Delete File
Delete File
Delete key
Delete Key
Delete Value
Delete value
Delimited variable
Delimited variable
Dial Up/Hang Up
Dial Up/Hang Up
Disable Automation
Disable Automation
Download Files
Download Files
Else
Else
Enable Automation
Enable Automation
Enable Task
Enable Task
Disable Task
End If
End If
End Loop
End Loop
Exit RoboTask
Exit RoboTask
Export
Export
Extract Files
Extract Files
File Loop
File Loop
FTP Change Folder
FTP Change Folder
FTP Command
FTP Command
FTP Create Folder
FTP Create Folder
FTP Delete File
FTP Delete File
FTP Download
FTP Download
FTP File Loop
FTP File Loop
FTP Log Off
FTP Log Off
FTP Log On
FTP Log On
FTP PWD
FTP PWD
FTP Remove Folder
FTP Remove Folder
FTP Rename File
FTP Rename File
FTP Upload
FTP Upload
If Then
If Then
Import
Import
Increment Variable
Increment Variable
Input box
Input Box
Lock Workstation
Lock Workstation
Log Message
Log Message
Log Off
Log Off
Minimize RoboTask
Minimize RoboTask
Open Dialog
Open Dialog
Pack Files
Pack Files
Pause
Pause
Ping Host
Ping Host
Print Document
Print Document
query
SQL Query
Question Dialog
Question Dialog
Read Value
Read Value
Remove Folder
Remove Folder
Remove Variable
Remove Variable
Rename File
Rename File
Rename Folder
Rename Folder
Rename key
Rename Key
Rename Value
Rename value
Restore RoboTask
Restore RoboTask
Run Program/Open Document
Save Dialog
Save Dialog
Search for Files
Search for Files
Send command
Send Command
Send Email
Send Email
Send Keystrokes
Send Keystrokes
Send Network Message
Set Variable
Set Variable
Show Message/Play Sound
Simple Loop
Simple Loop
Start Service
Start Service
Start Task
Start Task
Stop Service
Stop Service
Stop Task
Stop Task
Synchronize Folders
Synchronize Folders
Text Loop
Text Loop
Transfer Type
FTP Transfer Type
Wait for File
Wait for file
wait for process
Wait for process
Wait for Task
Wait for Task
Window Command
Window Command
Window Loop
Window loop
Write Text File
Write Text File
Write Value
Write Value
Add key
Add key
administrative commands
Minimize RoboTask
Restore RoboTask
Exit RoboTask
alarm clock
Scheduler
archiving
files
Pack Files
assistance
getting
Help > Help Topics
automation
disabling
Disable Automation
enabling
Tools > Enable Automation
Enable Automation
- B -
Basic
evaluate expression
Evaluate
RoboTaskApp object
RoboTaskApp object
script
Basic script
RoboTaskApp object
battery power
triggering event
On Battery Power is Low
beginning
RoboTask
Getting Started in the RoboTask Window
Break
Break
loops
Break
browse dialog box
displaying
Browse for Folders
bugs
reporting
Help > Send Bug Report
buying
RoboTask
Purchasing
- C -
CD/DVD writer
eject
Eject/Load CD Tray
Erase disk
Erase Disk
Write to disk
Write to disk
changing
directories
Change Folder
folders
Change Folder
Check connection
Check connection
Check email
POP3 Messages Count
checking
e-mail
Check for Email
for windows
Check for Window
Clear Clipboard
Clear Clipboard
Click the button
Click
Clipboard
copy
Copy
Cut
Cut
get
Get text
paste
Paste
put
Put Text
Clipoard
clear
Clear Clipboard
closing
windows
Window Command
commands
using ftp
FTP Command
comma-separated string
Delimited variable
comment
Comment
computer display
triggering event
On Display Changed
computer idle
triggering event
On Idle
computers
locking
Lock Workstation
shutting down
Log Off
conditional statements
using
If Then
Else
End If
connecting
dial-up connections
Dial Up/Hang Up
Continue
Continue
Copy
Copy
files
Copy/Move File
tasks
Task > Duplicate
creating
directories
Create Folder
expressions
Create a Variable
file lists
Search for Files
folders
Create Folder
tasks
Create Tasks
Task > New
text files
Write Text File
variables
Create a Variable
Create Variable
Zip files
Pack Files
customizing
options
Customize RoboTask
Cut
Cut
cyclic
triggering event
Cyclic
- D -
database
SQL Query
datasets
looping
Dataset Loop
delaying
tasks
Pause
delete email
POP3 Delete Email
Delete key
Delete Key
Delete Value
Delete value
deleting
files
Delete File
FTP Delete File
ftp
FTP Delete File
tasks
Task > Delete
device changed
triggering event
On Device Changed
Dial Up
Check connection
Check connection
dial-up connection monitor
triggering event
Dial-Up Connection Monitor
dial-up connections
making
Dial Up/Hang Up
directories
changing
Change Folder
FTP Change Folder
creating
Create Folder
FTP Create Folder
printing
FTP PWD
removing
Remove Folder
FTP Remove Folder
renaming
Rename Folder
synchronizing
Synchronize Folders
transferring
FTP Transfer Type
disabling
tasks
Tools > Disable All Tasks in List
Disable Task
display
triggering event
On Display Changed
documents
opening
printing
Print Document
Downloading
email
POP3 Download Email
files
Download Files
ftp
FTP Download
duplicating
tasks
Task > Duplicate
- E -
editing
tasks
Edit Tasks
Task > Edit
eject CD Tray
Eject/Load CD Tray
Else statements
using
Else
e-mail
checking
Check for Email
sending
Send Email
enabling
automation
tasks
Tools > Enable All Tasks in List
End If statements
using
End If
End Loop
End Loop
Erase to disk
Erase Disk
error handling
Errors processing
error processing
Errors processing
evaluate expression
Evaluate
events
Cyclic
Cyclic
File Monitor
File Monitor
Hot Keys
Hot Keys
On Device Changed
On Device Changed
On Display Changed
On Display Changed
On Idle
On Idle
On Log Off
On Log Off
On Palette Changed
On Palette Changed
On Spooler Changed
On Spooler Changed
On Time Changed
On Time Changed
Scheduler
Scheduler
Tray Icon
Tray Icon
Window Watcher
Window Watcher
exiting
RoboTask
Task > Exit
Exit RoboTask
Export Registry
Export
expressions
creating
Create a Variable
Create Variable
deleting
Remove Variable
modifying
Options > Variables
overview
Using Variables
removing
Remove Variable
setting
Set Variable
starting
Start Task
- F -
file lists
creating
Search for Files
File Loop
File Loop
ftp
FTP File Loop
file monitor
triggering event
File Monitor
files
archiving
Pack Files
copying
Copy/Move File
creating
Write Text File
deleting
Delete File
FTP Delete File
downloading
Download Files
FTP Download
extracting
Extract Files
looping
File Loop
moving
Copy/Move File
renaming
Rename File
FTP Rename File
searching
Search for Files
synchronizing
Synchronize Folders
transferring
FTP Transfer Type
unzipping
Extract Files
uploading
FTP Upload
zipping
Pack Files
focusing
windows
Window Command
folders
changing
Change Folder
FTP Change Folder
creating
Create Folder
FTP Create Folder
printing
FTP PWD
removing
Remove Folder
FTP Remove Folder
renaming
Rename Folder
synchronizing
Synchronize Folders
transferring
FTP Transfer Type
ftp
changing folders
FTP Change Folder
creating folders
FTP Create Folder
deleting
FTP Delete File
download
FTP Download
file loops
FTP File Loop
log off
FTP Log Off
log on
FTP Log On
PWD
FTP PWD
removing folders
FTP Remove Folder
renaming files
FTP Rename File
transfer
FTP Transfer Type
uploading
FTP Upload
using commands
FTP Command
FTP File Loop
FTP File Loop
- G -
Get Text
Get text
getting started
- H -
Help
opening
Help > Help Topics
hiding
windows
Window Command
hosts
pinging
Ping Host
hot keys
triggering event
Hot Keys
HTTP
downloading
Download Files
- I -
idle
triggering event
On Idle
If Then statements
using
If Then
Import Registry
Import
Incoming email
POP3 Open
POP3 Close
POP3 Mail Loop
POP3 Download Email
POP3 Delete Email
Parse Email
increment
Increment Variable
Input box
Input Box
introduction
Features
- J -
jobs
adding variables
Add Variables to a Task
creating
Create Tasks
Task > New
creating shortcuts
Task > Create Shortcut on Desktop
deleting
Task > Delete
disabling
Disable Task
duplicating
Task > Duplicate
editing
Edit Tasks
Task > Edit
running
Run Tasks
Task > Run
starting
Enable Task
Enable Automation
stopping
Task > Stop
Disable Task
Disable Automation
- K -
keyboard
strokes for
Send Keystrokes
keystrokes
sending
Send Keystrokes
- L -
Legal notice
License Agreement
listener
Listener
locking
computers
Lock Workstation
log off
ftp
FTP Log Off
triggering event
On Log Off
log on
ftp
FTP Log On
logging
messages
Log Message
computers
Log Off
logoff
Log Off
logs
viewing
Options > View Log
Loop
POP3 Mail Loop
datasets
Dataset Loop
files
File Loop
queries
Dataset Loop
simple
Simple Loop
text
Text Loop
Window
Window loop
loops
While loop
breaking
Break
continuing
Continue
ending
End Loop
iterating
FTP File Loop
- M -
Mail loop
POP3 Messages Count
maximizing
windows
Window Command
messages
displaying
logging
Log Message
sending
Messages count
POP3 Messages Count
minimizing
RoboTask
Minimize RoboTask
windows
Window Command
Mouse
click
Click
move pointer
Move
move to object
Move to object
Move mouse pointer
Move
Move pointer to object
Move to object
Move to Object
Move to object
moving
files
Copy/Move File
- N -
Network
listener
Listener
plugin settings
Network Plugin settings
send command
Send Command
sending
networking
dial-up connections
Dial Up/Hang Up
- O -
open dialog box
displaying
Open Dialog
options
customizing
Customize RoboTask
setting
Options > Settings
overview
Features
- P -
packing
Zip files
Extract Files
palette
triggering event
On Palette Changed
Parse
Parse Email
Paste
Paste
pinging
hosts
Ping Host
Pop3 Server
POP3 Open
POP3 Close
POP3 Mail Loop
POP3 Download Email
POP3 Delete Email
Parse Email
practical recommendations
custom variables
Custom variables
task synchronization
Task synchronization
tasks
Running tasks simultaneously
printing
documents
Print Document
folders
FTP PWD
process
Wait for process
programs
running
purchasing
RoboTask
Purchasing
Put Text
Put Text
- Q -
queries
looping
Dataset Loop
query
SQL Query
loops
Dataset Loop
question dialog box
displaying
Question Dialog
quitting
RoboTask
Exit RoboTask
- R -
Read Value
Read Value
registering
RoboTask
Purchasing
Registry
Add key
Add key
Delete key
Delete Key
Delete Value
Delete value
Export
Export
Import
Import
Read Value
Read Value
Rename key
Rename Key
Rename Value
Rename value
Write Value
Write Value
remote servers
checking
Ping Host
removing
directories
Remove Folder
folders
Remove Folder
variables
Remove Variable
Rename key
Rename Key
Rename Value
Rename value
renaming
directories
Rename Folder
files
Rename File
FTP Rename File
folders
Rename Folder
ftp
FTP Rename File
reporting
bugs
restoring
RoboTask
Restore RoboTask
windows
Window Command
RoboTask
exiting
Exit RoboTask
minimizing
Minimize RoboTask
restoring
Restore RoboTask
stopping
Task > Exit
Run Script
Basic script
running
tasks
Run Tasks
Task > Run
- S -
save dialog box
displaying
Save Dialog
schedulers
triggering event
Scheduler
searching
files
Search for Files
Send command
Send Command
Send Keystrokes
sending
e-mail
Send Email
keystrokes
Send Keystrokes
services
starting
Start Service
stopping
Stop Service
setting
options
Options > Settings
variables
Set Variable
shortcuts
creating
shut down
triggering event
On Log Off
shutting down
computers
Log Off
Simple Loop
Simple Loop
using
File Loop
Simple Loop
sound
playing
spooler
triggering event
On Spooler Changed
SQL
loops
Dataset Loop
SQL query
SQL Query
starting
services
Start Service
tasks
Enable Task
Start Task
Stop Task
Stop Task
stopping
RoboTask
Task > Exit
Exit RoboTask
services
Stop Service
tasks
Task > Stop
synchronize tasks
Wait for Task
Synchronize workstations
Send Command
Listener
synchronizing
directories
Synchronize Folders
files
Synchronize Folders
folders
Synchronize Folders
system time
triggering event
On Time Changed
System variables
System variables
displaying
Options > Variables
- T -
tasks
adding variables
copying
Task > Duplicate
creating
Create Tasks
Task > New
creating shortcuts
delaying
Pause
deleting
Task > Delete
disabling
Disable Task
duplicating
Task > Duplicate
editing
Edit Tasks
Task > Edit
enabling
Enable Task
running
Run Tasks
Task > Run
starting
Enable Task
Start Task
Enable Automation
stopping
Task > Stop
Disable Task
Stop Task
Disable Automation
waiting
Wait for Task
technical support
Help > Help Topics
text
creating
Write Text File
looping
Text Loop
creating
Write Text File
toolbars
viewing
Options > View Toolbar
Total size
POP3 Messages Count
transferring
files
FTP Transfer Type
tray icon
triggering event
Tray Icon
triggering events
Cyclic
Cyclic
File Monitor
File Monitor
Hot Keys
Hot Keys
On Device Changed
On Device Changed
On Display Changed
On Display Changed
On Idle
On Idle
On Log Off
On Log Off
On Palette Changed
On Palette Changed
On Spooler Changed
On Spooler Changed
On Time Changed
On Time Changed
Scheduler
Scheduler
Tray Icon
Tray Icon
Window Watcher
Window Watcher
- U -
unhiding
windows
Window Command
unzipping
files
Extract Files
uploading
ftp
FTP Upload
user variables
displaying
Options > Variables
user-defined variables
Using Basic
Using built-in Basic
- V -
Variables
System variables
Custom variables
adding to tasks
creating
Create a Variable
Create Variable
deleting
Remove Variable
Delimited variable
Delimited variable
increment
Increment Variable
modifying
Options > Variables
overview
Using Variables
removing
Remove Variable
setting
Set Variable
viewing
logs
Options > View Log
toolbars
- W -
Wait for File
Wait for file
wait for process
Wait for process
Wait for Task
Wait for Task
Wait for window
Wait for Window
While loop
While loop
Window
Wait for Window
Window loop
Window loop
window watcher
triggering event
Window Watcher
windows
checking for
Check for Window
focusing
Window Command
hiding
Window Command
manipulating
Window Command
maximizing
Window Command
minimizing
Window Command
restoring
Window Command
unhiding
Window Command
Windows NT/2000 services
Start Service
Stop Service
WinPopup
sending
Write to disk
Write to disk
Write Value
Write Value
- Z -
Zip files
creating
Pack Files
extracting
Extract Files
