Keyword Index
Table of Contents
Home page
- A -
actions
Add key
Break
Browse for Computers
Browse for Folders
Change Folder
Check connection
Check for E-mail
Check for Window
comment
Continue
Copy/Move File
Create Folder
Create Variable
Dataset Loop
Delete File
Delete key
Delete Value
Delimited variable
Dial Up/Hang Up
Disable Automation
Download Files
Else
Enable Automation
Enable Task
End If
End Loop
Exit RoboTask
Export
Extract Files
File Attributes
File Loop
FTP Change Folder
FTP Command
FTP Create Folder
FTP Delete File
FTP Download
FTP File Loop
FTP Log Off
FTP Log On
FTP PWD
FTP Remove Folder
FTP Rename File
FTP Upload
If Then
Import
Increment Variable
Input box
Lock Workstation
Log Message
Log Off
Minimize RoboTask
Open Dialog
Pack Files
Pause
Ping Host
Print Document
query
Question Dialog
Read Value
Remove Folder
Remove Variable
Rename File
Rename Folder
Rename key
Rename Value
Restore RoboTask
Run as User
Run Program/Open Document
Save Dialog
Search for Files
Send command
Send Email
Send Keystrokes
Send Network Message
Set Variable
Shif Keys State
Show Message/Play Sound
Simple Loop
Sort Text
Start Service
Start Task
Stop Service
Stop Task
Synchronize Folders
Terminate Process
Text Loop
Transfer Type
Unique File Name
Wait for File
wait for process finish
wait for process startfinish
Wait for Task
Window Command
Window Loop
Write Text File
Write Value
Add key
administrative commands
alarm clock
archiving
files
Ascending
assistance
getting
automation
disabling
enabling
- B -
basic
evaluate expression
RoboTaskApp object
script
Basic script
battery power
triggering event
beginning
RoboTask
Break
breaking
loops
browse dialog box
displaying
bugs
reporting
buying
RoboTask
- C -
CD/DVD writer
eject
Erase disk
Write to disk
changing
directories
folders
Check connection
Check email
checking
e-mail
for windows
Clear Clipboard
Click the button
Client-Server
Clipboard
copy
Cut
get
paste
put
Clipoard
clear
closing
windows
commands
using ftp
comma-separated string
comment
computer display
triggering event
computer idle
triggering event
computers
locking
shutting down
conditional statements
using
Connect to
connecting
dial-up connections
Continue
Copy
copying
files
tasks
creating
directories
expressions
file lists
folders
tasks
text files
variables
Zip files
Custom variables
customizing
options
Cut
cyclic
triggering event
- D -
database
datasets
looping
Define connections
delaying
tasks
delete email
Delete key
Delete Value
deleting
files
ftp
tasks
Descending
device changed
triggering event
Dial Up
Check connection
dial-up connection monitor
triggering event
dial-up connections
making
directories
changing
creating
printing
removing
renaming
synchronizing
transferring
disabling
tasks
display
triggering event
documents
opening
printing
Downloading
email
files
ftp
duplicating
tasks
- E -
editing
tasks
eject CD Tray
Else statements
using
e-mail
checking
sending
enabling
automation
tasks
End If statements
using
End Loop
Erase to disk
error handling
error processing
evaluate expression
events
Cyclic
Dial-Up Connection Monitor
Expression Monitor
File Monitor
Hot Keys
On Battery Power is Low
On Device Changed
On Display Changed
On Idle
On Log Off
On Palette Changed
On Spooler Changed
On Time Changed
Scheduler
Tray Icon
Window Watcher
exiting
RoboTask
Export Registry
Expression Monitor
triggering event
expressions
creating
deleting
modifying
overview
removing
setting
starting
- F -
File Attributes
file lists
creating
File Loop
file loops
ftp
file monitor
triggering event
files
archiving
copying
creating
deleting
downloading
extracting
looping
moving
renaming
searching
synchronizing
transferring
unzipping
uploading
zipping
Fill
Web Form
Fill web form
focusing
windows
folders
changing
creating
printing
removing
renaming
synchronizing
transferring
ftp
changing folders
creating folders
deleting
download
file loops
log off
log on
PWD
removing folders
renaming files
transfer
uploading
using commands
FTP File Loop
- G -
Get Text
getting started
- H -
Help
opening
hiding
windows
hosts
pinging
hot keys
triggering event
HTTP
downloading
- I -
idle
triggering event
If Then statements
using
Import Registry
Incoming email
increment
Input box
introduction
IsError
- J -
jobs
adding variables
creating
creating shortcuts
deleting
disabling
duplicating
editing
running
starting
stopping
- K -
keyboard
hold down keys
release keys
strokes for
keystrokes
sending
- L -
LastErrorCode
LastErrorDescription
LastErrorStep
LastErrorTaskExternalName
LastErrorTaskID
Legal notice
listener
local variables
locking
computers
log off
ftp
triggering event
log on
ftp
logging
messages
logging off
computers
logoff
logs
viewing
Loop
looping
datasets
files
queries
simple
text
Window
loops
breaking
continuing
ending
iterating
- M -
Macro recorder
Mail loop
maximizing
windows
messages
displaying
logging
sending
Messages count
minimizing
RoboTask
windows
Mouse
click
move pointer
move to object
Move mouse pointer
Move pointer to object
Move to Object
moving
files
- N -
Network
Client
Connect to
Control remote
Defined connections
listener
plugin settings
send command
Server
network messages
sending
networking
dial-up connections
- O -
open dialog box
displaying
options
customizing
setting
overview
- P -
packing
Zip files
palette
triggering event
Parse
Paste
pinging
hosts
Pop3 Server
practical recommendations
custom variables
Debugging
task synchronization
tasks
printing
documents
folders
process
programs
running
purchasing
RoboTask
Put Text
- Q -
queries
looping
query
querying
loops
question dialog box
displaying
quitting
RoboTask
- R -
RDC
Read Value
Record a macro
RegExp
loop
match
replace
RegExp Com object
registering
RoboTask
Registry
Add key
Delete key
Delete Value
Export
Import
Read Value
Rename key
Rename Value
Write Value
Regular Expressions
remote servers
checking
removing
directories
folders
variables
Rename key
Rename Value
renaming
directories
files
folders
ftp
reporting
bugs
restoring
RoboTask
windows
RoboTask
exiting
minimizing
restoring
stopping
Run as User
Run Script
running
tasks
- S -
save dialog box
displaying
schedulers
triggering event
searching
files
Send command
Send Keystrokes
sending
e-mail
keystrokes
services
starting
stopping
setting
options
variables
shortcuts
creating
shut down
triggering event
shutting down
computers
Simple Loop
simple loops
using
Sort Text
sound
playing
spooler
triggering event
SQL
loops
query
starting
services
tasks
Stop Task
stopping
RoboTask
services
tasks
String
between
delete
extract
pos
replace
trim
Strings
synchronize tasks
Synchronize workstations
synchronizing
directories
files
folders
system time
triggering event
System variables
displaying
- T -
tasks
adding variables
copying
creating
creating shortcuts
delaying
deleting
disabling
duplicating
editing
enabling
running
starting
stopping
waiting
technical support
Terminate Process
text
looping
Text file
text files
creating
toolbars
viewing
Total size
transferring
files
tray icon
triggering event
triggering events
Cyclic
Expression Monitor
File Monitor
Hot Keys
On Device Changed
On Display Changed
On Idle
On Log Off
On Palette Changed
On Spooler Changed
On Time Changed
Scheduler
Tray Icon
Window Watcher
- U -
unhiding
windows
Unique File Name
unzipping
files
uploading
ftp
user variables
displaying
user-defined variables
Using Basic
- V -
Variables
adding to tasks
creating
deleting
Delimited variable
increment
list
modifying
overview
removing
setting
viewing
logs
toolbars
Vista
- W -
Wait for File
wait for process
Wait for Task
Wait for window
Web
Document
Documents
Form
Forms
While loop
Window
Window loop
window watcher
triggering event
windows
checking for
focusing
hiding
manipulating
maximizing
minimizing
restoring
unhiding
Windows 2008 Server
Windows 7
Windows NT/2000 services
WinPopup
sending
Working as system service
differences
RDC
Vista
Write to disk
Write Value
- Z -
Zip files
creating
extracting
