Unzip files via sFTP command
nuphero
Post by nuphero »
Hi, I want to upload and unzip a lot of .zip files using Robotask sFTP command action, but unzip command didn't work.
ActionID=STRING|"A_SFTP_COMMAND"
Name=STRING|"SFTP command (unzip 1.zip)"
command=STRING|"unzip 1.zip"
But other commands like mkdir worked and it also worked when I tried unzip command on Putty. Could you please explain for me why unzip command did not work?
Thanks
Re: Unzip files via sFTP command
unzip is not an internal command of sFTP
To run local command of server use ! :
!unzip 1.zip
available commands are:
!      run a local command
bye    finish your SFTP session
cd     change your remote working directory
chmod  change file permissions and modes
close  finish your SFTP session but do not quit PSFTP
del    delete files on the remote server
dir    list remote files
exit   finish your SFTP session
get    download a file from the server to your local machine
help   give help
lcd    change local working directory
lpwd   print local working directory
ls     list remote files
mget   download multiple files at once
mkdir  create directories on the remote server
mput   upload multiple files at once
mv     move or rename file(s) on the remote server
open   connect to a host
put    upload a file from your local machine to the server
pwd    print your remote working directory
quit   finish your SFTP session
reget  continue downloading files
ren    move or rename file(s) on the remote server
reput  continue uploading files
rm     delete files on the remote server
rmdir  remove directories on the remote server
nuphero
Post by nuphero »
Thanks for quick reply,
I don't know much about Linux, and put ! like you said but it still does not work
Name=STRING|"SFTP command (!unzip 1.zip)"
I do not fully understand why, so I just use a small PHP script to do the unzip work.
Thanks for your time
