Working with workdays
Dear Robotaskers,
My "normal" Robotask skills are good, but programming is too far away for me. What is the situation?
The local financial department wants to have a process of creating a financial report automated. In fact no problem but there is a special condition.
Normally, the report uses a variable "end date" which is always 31-[mm]-[yyyy], even when it's February. The program which gets this input from Robotask accepts this. Thankgod!
BUT!
If the moment of execution of the task is on the 4th WORKING day of the current month or earlier, then the "end date" should be 31-[mm]-[yyyy]
of the PREVIOUS month, so something like 31-[mm-1]-[yyyy]. So, if the report is being executed on 04-02-2016 (DD-MM-YYYY) which is a Thursday, the end date must be 31-01-2016.
If the moment of execution of the task is on the 5th WORKING day of the current month or later, then the "end date" should be 31-[mm]-[yyyy]
of the CURRENT month.
So, if the report is being executed on 05-02-2016 (DD-MM-YYYY) which is a Friday, the end date must be 31-02-2016.
Somewhere I have to define the workdays (Monday till Friday) and I have to combine it with a IF, THEN, ELSE statement. The question is: how can I solve this?
Thanks in advance!
Re: Working with workdays
Let I formulate the job:
You have some date in format DD-MM-YYYY
You need to calculate the LASTDATE
if DD from 1 to 4 then the LASTDATE equals to 31-(MM-1)-YYYY
if DD from 5 to 31 then the LASTDATE equals to 31-MM-YYYY
Did I understood you correctly? If so, I can write small example to you.
Thanks for your quick reply, Oleg.
You're almost there. The question is not DD from 1 to 4 (just the number of days), but it's about working days, Mon, Tue, Wed, Thu and Fri.
If #workingday in a month <= 4, then the LASTDATE equals to 31-(MM-1)-YYYY
If #workingday in a month => 5, then the LASTDATE equals to 31-(MM)-YYYY
For example we take June 2016:
June 1, 2 and 3 are working days. June 4 and 5 not. June 6 is again a working day, but it's the 4TH workingday of that month. Then is still should be 31-(MM-1)-YYYY. From June 7th and further (= 5th working day) it should be 31-(MM)-YYYY.
Let's call this a challenge :D
What about Saturday and Sunday? Raise an error?
The task itself runs only on workdays (Mo .. Fr). In fact he should give no error :lol:
Maybe we have to think of an array with only the 5 working days in it, no idea. Just guessing.
See the example below
ExternalName=STRING|"Task53"
ID=INTEGER|239237499
Name=STRING|"Last Date"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Enabled=INTEGER|0
Name=STRING|"Set variable ""CURRENTDT"" with value ""{DateTimeToFormat({Date},dd-mm-yyyy)}"""
varname=STRING|"CURRENTDT"
varvalue=STRING|"{DateTimeToFormat({Date},dd-mm-yyyy)}"
Name=STRING|"If Then (month = 1)"
type=STRING|"1"
value1=STRING|"{mm}"
value2=STRING|"1"
Name=STRING|"Increment variable ""yy"""
incement=STRING|"-1"
vaiable=STRING|"yy"
Name=STRING|"Set variable ""LASTDATE"" with value ""31-12-{yy}"""
[Actions\Action12\Params]
varname=STRING|"LASTDATE"
varvalue=STRING|"31-12-{yy}"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
[Actions\Action14]
Name=STRING|"Increment variable ""mm"""
[Actions\Action14\Params]
vaiable=STRING|"mm"
[Actions\Action15]
[Actions\Action15\Params]
operator=STRING|"5"
type=STRING|"1"
value2=STRING|"10"
[Actions\Action16]
Name=STRING|"Set variable ""MM"" with value ""0{mm}"""
[Actions\Action16\Params]
varname=STRING|"MM"
varvalue=STRING|"0{mm}"
[Actions\Action17]
[Actions\Action18]
Name=STRING|"Set variable ""LASTDATE"" with value ""31-{mm}-{yy}"""
[Actions\Action18\Params]
varvalue=STRING|"31-{mm}-{yy}"
[Actions\Action19]
Name=STRING|"Set variable ""CURRENTDT"" with value ""03-02-2016"""
varvalue=STRING|"03-02-2016"
[Actions\Action20]
[Actions\Action21]
Name=STRING|"Show ""Current date = {currentDT}"""
[Actions\Action21\Params]
msg0=STRING|"Current date = {currentDT}"
msg2=STRING|"Last date = {LastDate}"
msgcount=STRING|"3"
Name=STRING|"Set variable ""LASTDATE"" with value ""UNKNOWN"""
varvalue=STRING|"UNKNOWN"
Name=STRING|"STR Extract (day)"
amount=STRING|"2"
from=STRING|"1"
source=STRING|"{CurrentDT}"
variable=STRING|"dd"
Name=STRING|"STR Extract (month)"
amount=STRING|"2"
from=STRING|"4"
variable=STRING|"mm"
Name=STRING|"STR Extract (year)"
amount=STRING|"4"
from=STRING|"7"
variable=STRING|"yy"
Name=STRING|"If Then (day >= 5)"
operator=STRING|"2"
type=STRING|"1"
value1=STRING|"{dd}"
value2=STRING|"5"
Name=STRING|"Else"
Many thanks! I will give it a try and let you know!
I have tested it and the script works perfectly. But....he "counts" the total number of days, including weekends. He should only count workingdays.....
I've tried to convince the Fin. dept. to change it, but it was no option :roll:
Look at the task version 2
I added the step #7 (JS Evaluate)
Unfortunately the usage of Javascript is more simple than calculation of this in simple actions of RoboTask.
Name=STRING|"Last Date (version 2)"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Enabled=INTEGER|0
Name=STRING|"Else"
type=STRING|"1"
value2=STRING|"1"
vaiable=STRING|"yy"
[Actions\Action13\Params]
[Actions\Action14]
Name=STRING|"Else"
[Actions\Action15]
vaiable=STRING|"mm"
[Actions\Action16]
operator=STRING|"5"
type=STRING|"1"
value2=STRING|"10"
[Actions\Action17]
[Actions\Action17\Params]
varname=STRING|"MM"
[Actions\Action18]
[Actions\Action19]
[Actions\Action19\Params]
Name=STRING|"Set variable ""CURRENTDT"" with value ""06-01-2016"""
varvalue=STRING|"06-01-2016"
[Actions\Action20]
[Actions\Action21]
[Actions\Action22]
[Actions\Action22\Params]
msgcount=STRING|"3"
amount=STRING|"2"
from=STRING|"1"
amount=STRING|"2"
from=STRING|"4"
amount=STRING|"4"
from=STRING|"7"
ActionID=STRING|"A_SCRIPT_JSEVALUATE"
Name=STRING|"JS Evaluate (calculates NUM of working day)"
expression=STRING|"getworkday({dd},{mm},{yy})"
line00000000=STRING|"function getworkday(d,m,y)"
line00000001=STRING|"{"
line00000002=STRING|"  workday = 0;"
line00000003=STRING|"  m--; // month begins from 0 in Javascript"
line00000004=STRING|"  dt = new Date(y, m, d);"
line00000006=STRING|"  weekday = dt.getDay();"
line00000007=STRING|"  // 0 Sunday"
line00000008=STRING|"  // 1 Monday"
line00000009=STRING|"  // 2 Tuesday"
line0000000A=STRING|"  // 3 Wednesday"
line0000000B=STRING|"  // 4 Thursday"
line0000000C=STRING|"  // 5 Friday"
line0000000D=STRING|"  // 6 Saturday"
line0000000E=STRING|"  for (i=d; i>0; i--)"
line0000000F=STRING|"    {"
line00000010=STRING|"      if ((weekday != 6) && (weekday != 0))"
line00000011=STRING|"        {"
line00000012=STRING|"          workday++;"
line00000013=STRING|"        }"
line00000014=STRING|"        weekday--;"
line00000015=STRING|"        if (weekday <0)"
line00000016=STRING|"          {weekday = 6;"
line00000017=STRING|"          }"
line00000018=STRING|"    }"
line00000019=STRING|"  return workday;"
line0000001A=STRING|"}"
line0000001C=STRING|"//LogMessage(getworkday(7,1,2016));"
linecount=STRING|"29"
loadfromfile=STRING|"1"
variable=STRING|"workday"
operator=STRING|"2"
type=STRING|"1"
value1=STRING|"{workday}"
value2=STRING|"5"
It works GREAT!!!!! Many thanks! :D :D :D
