Is there a possibility that Robotask can check if a task has been executed manually by the play button?
We are testing several tasks and if the task is run manually, the "emulation/testing/simulation" mode should be active and other variables should be used. As an example, a task generates by default a file. If the task is executed manually, the filename should be different instead of being executed or triggered the usual way.
I have been wondering this too, and here is how I have implemented a workaround -
1 - place a question dialog at start of task with text 'manual?' or 'are you there?' or something
2 - have the question dialog auto-select no after 2-3 seconds
3 - if yes is pressed, run manual settings in the task
can follow up question dialog (if yes pressed) with choice dialog to split task into differing sim modes
