Assign IP address to variable
verona
Post by verona »
Is there an easy way to assign the current system's IP
address to a variable? I don't see anything in RoboTask's
system variables or in the Windows environment variables
that has this info.
I'm hoping there's a way to do this through a Basic script
or perhaps a command line that could write to a file?
What address must be assigned if the computer have a few IP addresses? This situation is not rare.
verona
Post by verona »
I'm working with a pretty simple environment where there is
only be one IP address.
Alternatively, when using the Network/Send Command action,
is there a way for the receiving machine to capture the IP
address of the machine that sent the command?
Ok, we'll investigate the problem and, probably, we'll add this feature into next release.
See the variable {IPAddress({ComputerName})} in version 4.0
