New User - Powerpoint Presentation
Mitch
Post by Mitch »
Trying to make a task where every day of the week a powerpoint slide will run for that particular day.
Ex monday.ppsx, tuesday.ppsx
It will start at midnight each day.
You should set some variables with names of files.
Like this:
None,Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturda y
Suppose the variable name is MyFiles
Next you can use names so:
{MyFiles({DayOfWeekNo})}.ppsx
DayOfWeekNo begins from 1. Therefore the first element (zero element) will not be used.
Also see small example below:
CatID=INTEGER|101188231
ExternalName=STRING|"Task986"
ID=INTEGER|1521495323
LocalVariables=STRING|"MyFiles"
Name=STRING|"days of week"
Name=STRING|"Set variable ""MYFILES"" with value ""None,Sunday,Monday,Tuesday,Wednesday,Thursday,Frid..."""
varname=STRING|"MYFILES"
varvalue=STRING|"None,Sunday,Monday,Tuesday,Wednesday,Thursd ay,Friday,Saturday"
Name=STRING|"Show ""Now play the file:"""
msg0=STRING|"Now play the file:"
msg1=STRING|"{MyFiles({DayOfWeekNo})}.ppsx"
msgcount=STRING|"2"
