[Can I] open all images in folder
zubisid
Post by zubisid »
I am a student n00b to RoboTask
If new photos are added to a folder, it should open them in a photo slide. The monitoring part is easy, but can I use RoboTask (or with combination of another software) open all the new photos in a photo presentation?
Any help would be appreciated. I need it for a school project!
It depends on your photoviewer.
I simply run JPG file and my photoviewer shows it automatically.
See the example below.
Also you can find more examples here.
CatID=INTEGER|1709077872
ExternalName=STRING|"Task1051"
ID=INTEGER|176114585
LocalVariables=STRING|"photo_file"
Name=STRING|"Slideshow"
Name=STRING|"File Loop"
date1=STRING|"20110301"
date2=STRING|"20110301"
destvar=STRING|"PHOTO_FILE"
DuringMinutes=STRING|"1"
file0=STRING|"D:\Photos\*.JPG"
searchkind=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Run ""{photo_file} """
ifnonzero=STRING|"0"
program=STRING|"{photo_file}"
runas=STRING|"0"
wait=STRING|"0"
Name=STRING|"Delay 5000 ms"
delay=STRING|"50"
zubisid
Post by zubisid »
Thank you for your reply. You are most kind.
What I was doing is use IrfanView and command line to show the photos in full screen and slideshow format. It works but I need a text file with all the photos and it's full path
Now what I'm doing is I'm using File monitor+Save Changes to know what new files are coming into a folder. Then I'm using this file to pass it to IrfanView and it works well.
But - when new files are entered, the previous save changes log file gets overwritten. Is there any way I can append to the Save Changes file rather than overwrite it?
zubisid
Post by zubisid »
Never mind - thanks for your help. But did it!
