Space bar problem
manu
Space bar problem
Post by manu »
How to send "Space bar" in RoboTask??
edit:
I found it +( ) :)
Space bar problem
Yes, of course.
Maybe it's necessary to add some keyword such as {SPACEBAR} or something similar.
Spacebar is invisible symbol and therefore some confusion is possible.
waldo
Space bar problem
Post by waldo »
I am struggling to learn how to simulate a single press of the space bar.   How do you do this?  Thanks.
Space bar problem
You may use such expression: {chr(32)}
The character with code 32 is spacebar and you can use it instead spaces in the text.
This is useful if you want to use single spacebar or put trailing spaces to string
waldo
Space bar problem
Post by waldo »
Oleg--works perfect.  Thank you for the advice.  JimC
