Setting TimeOut for Download WEB file
agrafa
Post by agrafa »
Hi Can I change Setting TimeOut for Download web files task?
RoboTask uses system functions to download file. These functions uses global settings of Interner Explorer.
agrafa
Post by agrafa »
OK thank You for your help
For change:
Open your registry and find or create the key below.
Create a new DWORD value, or modify the existing value,
called "KeepAliveTimeout" and set it 60 000 for each
minute .
Restart Robotask
(from http://www.pctools.com/guides/registry/detail/1262/)
jemesright
Post by jemesright »
The maximum number of seconds a request is allowed to execute before
being automatically shut down by ASP.NET. Defaults to 90 seconds in
ASP.NET 1.x, 110 seconds in ASP.NET 2.0 and above.
