Use menu in running software
dima
Post by dima »
Hi, I need to run Firefox after that open an plugin with own menu.
I didn't find information in manual what means "Windows Caption\Windows class\Control text\Control class"
They uses in "Move to object" action.
How to manipulate an software by using menu ?
Thank you in advance!
Re: Use menu in running software
It's better to use keyboard if you want to use menu.
For example Alf-F calls File menu (as a rule). The combination for Send Keystroke action is %(F)
Single Alt-key activates main menu of a window (use "%()" in send keystrokes). Next you can use arrow-keys to choose necessary menu item.
Pay attention that many menu items have hot-key combination for direct call of the item.
