Put random text
richiehustle
Put random text
Post by richiehustle »
What is the right command of the programming language RoboTask uses to implement the following:
have a number of premade text that RoboTask shall pick at random and paste it?
Re: Put random text
See this example
CatID=INTEGER|1416408852
ExternalName=STRING|"Task45"
ID=INTEGER|1324567154
Name=STRING|"random text"
ToLog=INTEGER|2
Name=STRING|"Create local variable ""TEXT"" with value ""1-st line{EOL}Second line{EOL}3-d example line{EOL..."""
varname=STRING|"TEXT"
varvalue=STRING|"1-st line{EOL}Second line{EOL}3-d example line{EOL}4-th line{EOL}5-th line"
Name=STRING|"Set variable ""NUM"" with value ""{RandomValue(5)}"""
varname=STRING|"NUM"
varvalue=STRING|"{RandomValue(5)}"
incement=STRING|"1"
vaiable=STRING|"num"
external=STRING|"0"
line00000000=STRING|"{Text}"
linenum=STRING|"{num}"
variable=STRING|"Line"
Name=STRING|"Show ""{Line}"""
msg0=STRING|"{Line}"
