DateAdd bad result
WellWisher
DateAdd bad result
Post by WellWisher »
I need to add 2 dates:
DateAdd("H",0,"{TIME}")
but in the action "Evalute" error "Bad result format" and right answer.
Also Variable "{LastErrorDescription}" not show result, but in the log show " Bad result format: #3:35:59 PM#"
How to pull out the answer in a variable?
Re: DateAdd bad result
Use expression
CStr(DateAdd("H",0,"{TIME}"))
It seems you are using Evaluate action. This is deprecated.
You can use VB Evaluate action. It can calculate the expression
without problem
WellWisher
Thanks you very much, both result is worked!
