How to use Expression Monitor?
robo_wowving
Post by robo_wowving »
Dear Olev,
What is the syntax for using the expression Monitor? Please give an example? Is it possible to use symbols like greater than/less than in the expression monitor? Please reply ASAP
Re: How to use Expression Monitor?
Expression monitor is fired when the specified expression change its value.
read more about Expression monitor trigger here: https://robotask.com/help/index.php?exp ... onitor.htm
You can specify some expression with global variables. The trigger checks the expression every second and start the task when the expression changes the value.
