It becomes interesting but ...
ahmed
Post by ahmed »
Hi !It becomes interesting but :Is it possible to select a SubMenu Items with the mouse ?Thank you for your help !Ahmed
You can use Send keystrokes. Also it is more reliable.
Single Alt-key selects main menu (keystroke is "%()")
Next you can use arrow keys to select necessary item.
Also, look at menu of the program carefully. Many items have hot-keys.
For example (very frequent combinations)
Ctrl-o - open file
Ctrl-s - save file
Ctrl-c - copy to clipboard
Ctrl-v - paste from clipboard
and etc.
ahmed
Post by ahmed »
It's OK ! I do that.Thank you.
