"Wait" makes the script fail
AnkitaHundal
Post by AnkitaHundal »
Hi Oleg,
The wait for window option within a script always makes
my task to fail. The logs show an error stating that the
window could not be found,even when the window has
appeared on the screen. Somehow, it is not seeing the
screen come up.
I have selected hidden and child window watch and looking
for window to be activated and have incorporated a delay
in case the system takes some time to pull the screen up.
Something needs to be added or changed here?
Also, the scripts run when I initiate them manually,
however the when initiated by the scheduler, they always
seem to get stuck at some window and fail. It it
necessary for the Robotask window to be up? I understood
that it would anyhow initiate the tasks till the time it
is running locally on the machine.
Thanks
Ankita
Probably you have to check the existence of window before "Wait for window" action.
Wait for window waits the specified action.
For example: you want to wait for window creation. If required window exists, the action will wait another window with same parameters.
See my example below:
CatID=INTEGER|304847758
ExternalName=STRING|"Task957"
ID=INTEGER|1722185942
LocalVariables=STRING|"w"
Name=STRING|"Wait For Window example"
ActionID=STRING|"A_WINDOW_CHECK"
Name=STRING|"Check for Window"
abortif=STRING|"0"
action=STRING|"1"
checkfor=STRING|"0"
exact=STRING|"0"
variable=STRING|"w"
wincaption=STRING|"Registry Editor"
operator=STRING|"1"
value1=STRING|"{w}"
ActionID=STRING|"A_WAIT_FOR_WINDOW"
Name=STRING|"Wait For Window"
assignvariable=STRING|"0"
child=STRING|"0"
classexact=STRING|"0"
exact=STRING|"0"
hidden=STRING|"0"
infinity=STRING|"0"
timeout=STRING|"60"
usecaption=STRING|"1"
useclass=STRING|"0"
watchfor=STRING|"1"
msg1=STRING|"Window exists"
msgcount=STRING|"2"
AnkitaHundal
Got it!
Thanks!
