Copy form Computer that is off
Amerifax
Post by Amerifax »
I have a task that works fine when network computer is turned on. I copy files from several computes. The Problem is if one computer is off, the task will stop instead of going to the next computer to continue the copy.
Bob
Try to allow the task execution, when error occured. In edit task form click "Advanced" tab and set "If error occured" parameter to "Continue execution" value. You can check error presence by "IsError" macrofunction.
Amerifax
Post by Amerifax »
I feel like the guy that calls for tech support and and the support tech says you need to turn your computer on.
Thanks for the help.
Bob
