create task
Xomos
create task
Post by Xomos »
Could some very nice help me?J'd like to create task like this:1. use key stroke Clrl+N2. paste value: [sound:1.mp3]3. use key stroke Clrl+N4. paste value: [sound:2.mp3]5. use key stroke Clrl+N
6. paste value: [sound:3.mp3]7. use key stroke Clrl+N
8. paste value: [sound:4.mp3]etc up to 17 000J will be really grateful to some one that help meragards
create task
You should use the loop in your task.
See two examples with Text Loop and Simple Loop below:
Example #1:
CatID=INTEGER|125880069
ExternalName=STRING|"Task1128"
ID=INTEGER|437735173
LocalVariables=STRING|"cline"
Name=STRING|"Send keystrokes in the loop #1"
Name=STRING|"Text Loop"
destvar=STRING|"CLINE"
line0=STRING|"[sound:1.mp3]"
line1=STRING|"[sound:2.mp3]"
line2=STRING|"[sound:3.mp3]"
line3=STRING|"[sound:4.mp3]"
line4=STRING|"[sound:5.mp3]"
line5=STRING|"[sound:6.mp3]"
line6=STRING|"[sound:7.mp3]"
linecount=STRING|"7"
sourcetext=STRING|"1"
currentwindow=STRING|"1"
fixedwindow=STRING|"1"
keylayout=STRING|"0"
keys=STRING|"^(N)"
pause=STRING|"20"
release=STRING|"1"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
Name=STRING|"Put Text"
line0=STRING|"{cline}"
ActionID=STRING|"A_CLIPBOARD_PASTE"
Name=STRING|"Paste"
mode=STRING|"1"
Example #2:
ExternalName=STRING|"Task1129"
ID=INTEGER|1396995068
LocalVariables=STRING|"cline,num"
Name=STRING|"Send keystrokes in the loop #2"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"100"
variable=STRING|"NUM"
keys=STRING|"^(N)"
pause=STRING|"20"
release=STRING|"1"
sendkind=STRING|"0"
line0=STRING|"[sound:{num}.mp3]"
Name=STRING|"Paste"
mode=STRING|"1"
Xomos
create task
Post by Xomos »
thank You very much for your effort, but J don't know where should paste this script above?Could you export those scripts to "task file" and J just import them ?Also J'd like to know if script above paste at end [sound:17000.mp3] (after repeating itself 17000 times) ?once again thank you
create task
Save the text of script as simple text file and use menu Task->Import in order to import into RoboTask.
Next, you can see and edit imported task in task editor.
Xomos
create task
Post by Xomos »
Thank You for support everything work like J wanted.Merry Christmas !
