Window watcher, Window activated
User avatar
robotask
Post by robotask »
observed behavior on a x64 win7 enterprise system, with firefox window open/cycling through bookmarks, the opening of a new window does not trigger the task but only when another tab is clicked AND THEN back to the just opened bookmark/tab
it does not make any difference if using explicit full value string or partial match
User avatar
robotask
Re: Window watcher, Window activated
Post by robotask »
assuming this is a known bug in current release .... happens when firefox window title is used as the window watch
Just tested "Wimdow watcher" trigger on Windows 7 x64 with FireFox window.
It works properly.
User avatar
robotask
Post by robotask »
do not test with just firefox itselt, have FF and inside it several tabs open, to different web sites in ONE window
now open a new tab to a new site that is being watched
robotask will not respond .... until the focus is switched away to another window or clicking on desktop.... now return to that tab in firefox, only then does robotask find it
make sure you do this on a x64 bit version to replicate
New tab is not a new window. New tab is only element of existing window only
In this case you should use "Window change caption" parameter of the trigger.
If you open new tab the window of FF is already opened and it is already active. So the trigger doesn't react to this event.
Pay attention that the window of FF only changes own title (caption) in this case.
BTW: The same behavior is for Internet Explorer and Google Chrome
