VB-Script = Basic?
Helix78
VB-Script = Basic?
Post by Helix78 »
I have a VB-Script running from a CMD file now.
The CMD file get started by Robotask.
Can my script be integrated into the Basic Plugin?
> Internal / External Task Script
With Copy / Paste the code does not work.
Set xl = CreateObject("Excel.Application")
xl.Visible = False  'set to False for production
xl.Workbooks.Open("C:\blp\API\Office Tools\BloombergUI.xla")
Set wb = xl.Workbooks.Open(WScript.Arguments(0))
wscript.sleep 45000
wb.ActiveSheet.UsedRange.Value = wb.ActiveSheet.UsedRange.Value
wb.Save
wb.Close
xl.Quit
Re: VB-Script = Basic?
Basic is not equals to VB script language.
It have some differences.
But the language is very similar
Try this script and read my comments
You should create the variable MyVar in the task and set necessary value to it.
It should work.
Sub Main
	'Read the value from RoboTask Variable
	MyArgument = RoboTaskApp.ExpandText("{MyVar}")
	Set wb = xl.Workbooks.Open(MyArgument)
	'Use Wait finction instead of
	'wscript.sleep 45000
	Wait 45
	wb.Save
	wb.Close
	xl.Quit
End Sub
Helix78
Post by Helix78 »
Thank you a lot!
Works perfectly
Helix78
Post by Helix78 »
And how to save a value back to a Robotask variable?
? = wb.Range(B2).Value
Is there any documentation beside the "RoboTaskApp object"? There I didn't find it.
see RoboTaskApp.SetUserVariable
Look at RoboTaskApp chapter
the code is:
RoboTaskApp.SetUserVariable("MyVar",wb.Range(B2).Value)
Pay attention that the value must be a string.
RoboTask keeps user variables as strings.
