IF/Then Task
batesm0t3l
IF/Then Task
Post by batesm0t3l »
Hello.
Ive just bought RoboTask and I am starting to learn through the examples etc.
However, I was wondering can someone help me in how I would create an IF/Then Task to test that a Windows Drive letter exists.
Id much appreciate the help till I get up to speed.
Thank you.
M.
Re: IF/Then Task
Look at this example:
CatID=INTEGER|933306365
ExternalName=STRING|"Task1015"
ID=INTEGER|2144471300
Name=STRING|"Check drive"
operator=STRING|"7"
value1=STRING|"{TotalDiskSpace(i:\)}"
Name=STRING|"Show ""Drive I: desn't exist"""
icon=STRING|"0"
msg0=STRING|"Drive I: desn't exist"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Drive I: found"""
msg0=STRING|"Drive I: found"
msg1=STRING|"Total space = {TotalDiskSpace(i:\)}"
msgcount=STRING|"2"
Use system variable {TotalDiskSpace(i:\)}
If drive doesn't exists this variable returns empty string.
Otherwise it returns number value.
Save the text of the task into a file and use menu Task->Import to import the task into RoboTask.
batesm0t3l
Re: IF/Then Task
Thank you.
