Extracting text file to body of an email
TWSI
Post by TWSI »
Hello and Good Day! I am new to robotask and need help with the following.
I need to create a task that does the following.
01. Watch folder for new items. c:\toemail
02. Extract all text from record c:\toemail\01.txt
03. Write that extracted data to the body of an email.
04. Send the email. (mailto:whoever@yahoo.com)
05. Delete text file c:\toemail\01.txt
06. Loop until each text file has been read, extracted, emailed, & deleted.
07. Wait & watch for new items. (repeat again)
I don't know how many text files I may have in the folder, we may have up to 20 at one time which would be 20 emails.
Thanks in advance
David
Re: Extracting text file to body of an email
Just look at my example.
This task sends all TXT files to whoever@yahoo.com from folder c:\toemail
File monitor trigger detects new TXT file in the folder and launches the task automatically.
You need only to copy necessary files to folder c:\toemail
CatID=INTEGER|317955339
ExternalName=STRING|"Task65"
ID=INTEGER|188144622
Name=STRING|"Send texts via email"
Name=STRING|"File Loop"
date1=STRING|"20150406"
date2=STRING|"20150406"
destvar=STRING|"BODYTEXT"
DuringMinutes=STRING|"1"
file0=STRING|"c:\toemail\*.txt"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
ActionID=STRING|"A_FILE_WAIT"
Name=STRING|"Waiting {BodyText} file for 60 sec"
filename=STRING|"{BodyText}"
timeout=STRING|"60"
Name=STRING|"Send Email"
attachcount=STRING|"0"
auth=STRING|"0"
charset=STRING|"iso-8859-1"
from=STRING|"whoever@yahoo.com"
host=STRING|"my_smtp_server.com"
html=STRING|"0"
msg0=STRING|"{TextFile({BodyText})}"
password=STRING|"2565726990246892570624689"
passwordmode=STRING|"0"
port=STRING|"25"
SSL=STRING|"0"
subject=STRING|"The text {bodytext}"
xmailer=STRING|"RoboTask"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{BodyText}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
UnigueID=INTEGER|565518369
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"1"
folder1=STRING|"c:\toemail\"
foldercount=STRING|"1"
incmask=STRING|"*.txt"
interval=STRING|"60"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
pass=STRING|"0"
passmode=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"0"
TWSI
Post by TWSI »
Thanks for the help!!
This is the error message I am getting.
I: 4/6/2015 7:55:17 AM: ****** Starting task: Send texts via email (imported) ******************
I: 4/6/2015 7:55:17 AM: Executing "1.File Loop"
I: 4/6/2015 7:55:17 AM: Executing "2.Waiting {BodyText} file for 60 sec"
E: 4/6/2015 7:55:17 AM: File "{BodyText}" doesn't exist
E: 4/6/2015 7:55:17 AM: An error occurred. Step #2 (Waiting {BodyText} file for 60 sec).
E: 4/6/2015 7:55:17 AM: Task execution is aborted
TWSI
Post by TWSI »
I was able to get it to work by changing BODYFILE to BODYTEXT
TWSI wrote:I was able to get it to work by changing BODYFILE to BODYTEXT
Yes, of course. This is my mistake. Variable name should be BODYTEXT at 1-st step.
I have corrected the task in my message
