Mailing list problem
marcolobaido
Post by marcolobaido »
Hi, i tried to use the "text loop" action to send the same mail to a mailing list.
I wrote a text file in which I put all the mail addresses in different lines. I used "text loop", and "store current line to variable" {MAILLIST}.
I send the e-mail TO: {MAILLIST} with CC: my e-mail address (to control the process).
I: 06/12/15 18:56:46: Executing "1.Create local variable "MAILLIST" with value """
I: 06/12/15 18:56:46: Executing "2.Text Loop"
W: 06/12/15 18:56:46: Illegal name of variable ()
I: 06/12/15 18:56:46: Executing "3.Send Email"
I: 06/12/15 18:56:47: Executing "4.End Loop"
CatID=INTEGER|0
ExternalName=STRING|"Task38"
ID=INTEGER|1023130397
LocalVariables=STRING|"MAILLIST="
Name=STRING|"Loop mail"
Name=STRING|"Create local variable ""MAILLIST"" with value """""
varname=STRING|"MAILLIST"
Name=STRING|"Text Loop"
Re: Mailing list problem
This is incomplete task. You have missed a half of the task parameters...
But I think that the problem is that you specified variable name with braces "{}"
You have to specify variable name only in the loop
