Parse URL to obtain SID
jimvano
Post by jimvano »
I need to pull the URL after logging into a website and extract the session id (sid=) from the URL. Ideas?
Thanks,
Jim
Re: Parse URL to obtain SID
You can find SID by using regular expressions.
See example below
CatID=INTEGER|317955339
ExternalName=STRING|"Task11"
ID=INTEGER|1022341075
Name=STRING|"Extract SID from URL"
Name=STRING|"Create local variable ""MYURL"" with value ""http://www.mysite.com?sid=1234567890abcdef&param=a..."""
varname=STRING|"MYURL"
varvalue=STRING|"http://www.mysite.com?sid=1234567890abcdef&param=asdf&param=zxcv"
Name=STRING|"Show ""SID  is not found"""
icon=STRING|"0"
msg0=STRING|"SID  is not found"
Name=STRING|"RegExp Match"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{MyURL}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?i)sid=([^&]+)$"
savesubexpression=STRING|"1"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"found"
value1=STRING|"{found}"
Name=STRING|"Show ""Found! Expression is:"""
msg0=STRING|"Found! Expression is:"
msg1=STRING|"sid : {expr(1)}"
msgcount=STRING|"2"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
anchored=STRING|"0"
extended=STRING|"0"
pattern=STRING|"(?i)sid=([^&]+)&"
ungreedy=STRING|"0"
msgcount=STRING|"2"
Name=STRING|"Else"
Note: It is possible to avoid of usage of regular expressions, but the algorithm will be a bit more complex.
