date_time difference
rgonzalez
Post by rgonzalez »
Is there a way to add or substract minutes, hours, seconds, etc, to the current {DateTime}?
For example:
(current datetime) - (45 minutes) = datetime 45 minutes ago
(current datetime) - (1 hour and 5 minutes) = datetime 1 hour and 5 minutes ago
Or substracting any datetime to another datetime?
For example:
(datetime1) - (datetime2) = time elapsed
Thank you!
Re: date_time difference
You can do this with VB Evaluate action.
Look at my example below:
CatID=INTEGER|397884660
ExternalName=STRING|"Task67"
ID=INTEGER|1981151426
Name=STRING|"date-time subtracting"
Name=STRING|"Create local variable ""DT1"" with value ""{DateTime}"""
varname=STRING|"DT1"
varvalue=STRING|"{DateTime}"
Name=STRING|"Create local variable ""DT2"" with value ""00:45:10"""
varname=STRING|"DT2"
varvalue=STRING|"00:45:10"
Name=STRING|"VB Evaluate (dt1-dt2)"
expression=STRING|"datesubtract(""{dt1}"", ""{dt2}"")"
line00000000=STRING|"function DateSubtract(d1, d2)"
line00000001=STRING|"  'd1 and d2 are strings"
line00000002=STRING|"  dt1 = cdate(d1)"
line00000003=STRING|"  dt2 = cdate(d2)"
line00000005=STRING|"  'convert the result back to string"
line00000006=STRING|"  DateSubtract = cstr(cdate(dt1-dt2))"
line00000007=STRING|"end function"
line00000009=STRING|"'aaa = DateSubtract(""12.02.2016 10:41:00"", ""00:45:10"")"
line0000000A=STRING|"'logmessage(aaa)"
linecount=STRING|"11"
loadfromfile=STRING|"1"
variable=STRING|"dt3"
Name=STRING|"Show ""date-time1  = {dt1}"""
msg0=STRING|"date-time1  = {dt1}"
msg1=STRING|"date-time2  = {dt2}"
msg2=STRING|"-----------------------"
msg3=STRING|"result = {dt3}"
msgcount=STRING|"4"
rgonzalez
Post by rgonzalez »
This is great! :o Is there a web where I can see a list of those VB functions? :roll:
Thank you!
This link is in the RoboTask's help file
Read about VB script language here: https://msdn.microsoft.com/en-us/library/t0aew7h6(v=vs.84).aspx
The same information is in online help here: http://robotask.com/help/index.php?vb_script.htm
For javascript see here: http://robotask.com/help/index.php?js_script.htm
rgonzalez
Post by rgonzalez »
Perfect, thanks! :D
