Robotask cant find button in ribbon-bar of Word
snowseals
Post by snowseals »
I want to record a marco, so Robotask will click on a certain button in the ribbon bar of Word.
Since this ribbon-bar is customized, Robotasks ends with the message: cant find button.
How can I let Robotask 'click' this button?
See also:
Re: Robotask cant find button in ribbon-bar of Word
You can do this by using Send keystrokes action
Activate the window of MS Word and send these keys sequentially:
Alt, N, V
Pay attention, these keys for my MS Word with English localization.
For your Work maybe another keys. Press and release Alt -key in the word and you see keys in hints on the ribbon.
See my example below
The sequence "%()" is ALT-key simulation.
ExternalName=STRING|"Task119"
ID=INTEGER|-2020470416
Name=STRING|"MS Word Ribbon"
Name=STRING|"Focus window ""- Microsoft Word"""
action=STRING|"0"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"0"
classexact=STRING|"0"
exact=STRING|"0"
findmode=STRING|"0"
hidden=STRING|"0"
processall=STRING|"0"
wincaption=STRING|"- Microsoft Word"
Name=STRING|"Delay 200 ms"
delay=STRING|"200"
dimension=STRING|"0"
currentwindow=STRING|"1"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"%()NV"
pause=STRING|"20"
release=STRING|"1"
sendkind=STRING|"0"
Also see another example.
I just recorded the mouse by using MacroRecorder.
Next I changed "Windows caption" parameter in the steps #2, #5, #8 to "- Microsoft Word"
This is important, because the caption of the window may be changed.
ExternalName=STRING|"Task121"
ID=INTEGER|1862870897
Name=STRING|"MS Word Ribbon (1)"
Name=STRING|"//Begin of MacroRecoder block"
comment=STRING|"Begin of MacroRecoder block"
Name=STRING|"//End of MacroRecoder block"
comment=STRING|"End of MacroRecoder block"
ActionID=STRING|"A_MOUSE_MOVETO"
Name=STRING|"Move To Object"
bottom=STRING|"142"
controlclass=STRING|"NetUIHWND"
ctrlclassexact=STRING|"0"
ctrltextexact=STRING|"1"
left=STRING|"0"
right=STRING|"1858"
top=STRING|"0"
winclassexact=STRING|"0"
windowclass=STRING|"OpusApp"
windowtext=STRING|"- Microsoft Word"
wintextexact=STRING|"0"
x=STRING|"145"
y=STRING|"42"
Name=STRING|"Click button"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"8"
bottom=STRING|"142"
left=STRING|"0"
right=STRING|"1858"
top=STRING|"0"
x=STRING|"145"
y=STRING|"40"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"13"
bottom=STRING|"142"
left=STRING|"0"
right=STRING|"1858"
top=STRING|"0"
x=STRING|"24"
y=STRING|"80"
action=STRING|"0"
button=STRING|"0"
Save the text of the tasks to a files and use menu Task->Import to import the tasks into RoboTask.
snowseals
Post by snowseals »
Tried the 2nd one.. Works!
Thank you.
