Syncronize folders
adorni
Syncronize folders
Post by adorni »
Hi. I need to syncronize two folders BIDIRECTIONAL. I have the 6.5 version.
All works fine, EXCEPT the deleted files... when i delete in folder one or two one file, Robotask not delete the file in the other folder, only copy again from the other folder the file deleted.
Any idea?
Thanks
Re: Syncronize folders
The removing of files you deleted in the source folder is possible only in unidirectional mode. This is "Exact copy" parameter.
if you want to remove files from target folder, but make the bi-directional synchronization do the following:
Synchronize Folder1 to Folder2 (use Exact Copy)
Synchronize Folder2 to Folder1
Thus, you will remove files in Folder2 when you remove files in the Folder1 and you will have newest files in both folders.
adorni
Post by adorni »
In your example, when i delete file in folder one, all works fine. But, not work when i delete file in folder two.
Of course it doesn't work in this case.
You have to choose main folder for synchronization.
In my example the main folder is Folder1. Both folders can't be main
