Variable not accepted?
In a task, I declared a local variable Filename like this (works perfect in any other task).
I apply this in the screenshot function:
But, when I press "OK" and open it again, it became this:
When I fill in the path directly without variable it goes perfectly. How come?
Re: Variable not accepted?
Hm-m...
I've just tested the similar example - it works!
My example:
CatID=INTEGER|379259420
ExternalName=STRING|"Task14"
ID=INTEGER|754138547
LocalVariables=STRING|"FileName=c:\temp\img\{Year}-{MonthNo}-{Day}Test.png,kleur=$000000"
Name=STRING|"Screenshot..."
Name=STRING|"Create Folder ({ExtractFilePath({FileName})})"
newfolder=STRING|"{ExtractFilePath({FileName})}"
ActionID=STRING|"A_SCR_SCREEN"
Name=STRING|"Screenshot"
captureregion=STRING|"1"
filename=STRING|"{FileName}"
format=STRING|"2"
height=STRING|"519"
left=STRING|"58"
top=STRING|"122"
width=STRING|"1148"
I've tried your task and that works as well. I reviewed my task and add again the variable. This time it works. No clue why this happens.
