Alt+D to set focus in delay field doesn't work
Just to let you know: Alt + D (to focus the delay field) doesn't work here.
Re: Alt+D to set focus in delay field doesn't work
In the new version this is not fixed. Ofcourse, this is a very minor minor problem, but I think the focus should be on the value, not the OK button.
Than you can define straight away a new value if needed. The ENTER key has the same purpose, regardless the position of the focus at the moment.
We'll check all dialog forms in the project.
Not only this dialog contains such problem.
