"WAIT FOR FILE" => File doesn't exist.
userXXX
Post by userXXX »
What could be the reason for getting a "File doesn't exist."-error when using the "WAIT FOR FILE" action?
Re: "WAIT FOR FILE" => File doesn't exist.
Wait for File action waits until the selected file will be available for some operations.
If file doesn't exist the nothing to wait. This is error.
see the example how to process such situation:
CatID=INTEGER|1663346572
ExternalName=STRING|"Task26"
ID=INTEGER|1547760231
Name=STRING|"wait for file example"
Name=STRING|"Create local variable ""FILENAME"" with value ""d:\temp\nofile.txt"""
varname=STRING|"FILENAME"
varvalue=STRING|"d:\temp\nofile.txt"
value1=STRING|"{FileExists({filename})}"
ActionID=STRING|"A_FILE_WAIT"
Name=STRING|"Waiting {filename} file for 60 sec"
filename=STRING|"{filename}"
timeout=STRING|"60"
Name=STRING|"Show ""File {FileName} is free"""
msg0=STRING|"File {FileName} is free"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""File ""{FileName}"" doesn't exist"""
icon=STRING|"0"
msg0=STRING|"File ""{FileName}"" doesn't exist"
userXXX
Post by userXXX »
Hello Oleg,
thank you.
I see, this is not the functionality I'm looking for.
My scenario is:
Task A has to wait until Task B has created a file (Task A knows path and name of the file). Task A cannot wait until Task B has finished, so it has to wait for the file.
Any idea?
See the example below.
This task waits for file appearance during 1 minute
Maybe it's necessary to make such action later (or modify Wait For File action).
ExternalName=STRING|"Task30"
ID=INTEGER|669997716
Name=STRING|"wait for file appearance"
Name=STRING|"Show ""File {FileName} exists"""
msg0=STRING|"File {FileName} exists"
Name=STRING|"Else"
[Actions\Action12\Params]
icon=STRING|"0"
msg1=STRING|"Timeout is over"
msgcount=STRING|"2"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"60"
Name=STRING|"Break"
Name=STRING|"Else"
Name=STRING|"Delay 1 sec"
delay=STRING|"1"
dimension=STRING|"1"
userXXX
Post by userXXX »
Thank you, Oleg.
