Check for Window
userror
Check for Window
Post by userror »
(sorry for my bad English - Google Translation)
I'm need to Check open Three window (or More) of a program
What can I do?
tnx
Re: Check for Window
To check many windows there is simple algorithm.
You can use Check for Window and If..Then actions
When you check the window you have to assign the result to some variable. For example variable Result
Algorithm will be such:
Check for window1
if result then
  Check for window2
  if result then
    Check for window3
    if result then
       // and so on
    end if
  end if
end if
if result then
  // all windows are checked
else
  // the checking is failed
end if
