bug in open dialog?
marcolobaido
bug in open dialog?
Post by marcolobaido »
Hi, I was trying the new open dialog feature.
I think that something is inverted. When I select "allow to select several files" I can select only one file and vice versa.
Re: bug in open dialog?
Thank you for the report.
Annoying mistake...
Already corrected, download and install fresh copy please: http://robotask.com/downloads/RobotaskSetup.exe
Just curiosity, I just installed the update, but the version number is still "7.0.0.929". Why don't you change this?
Look at the version of Dialogs and Notifications plugin
I: 23.10.2017 14:58:52: Plugin "General (v 7.0.0.288)" is loaded
I: 23.10.2017 14:58:52: Plugin "Dialogs and Notifications (v 7.0.1.181)" is loaded
I: 23.10.2017 14:58:52: Plugin "Files and Folders (v 7.0.0.258)" is loaded
I: 23.10.2017 14:58:52: Plugin "Zip (v 7.0.0.169)" is loaded
I: 23.10.2017 14:58:52: Plugin "Internet (v 7.0.0.211)" is loaded
I: 23.10.2017 14:58:52: Plugin "FTP Commands (v 7.0.0.162)" is loaded
I: 23.10.2017 14:58:52: Plugin "SSL FTP Commands (v 7.0.0.110)" is loaded
I: 23.10.2017 14:58:52: Plugin "SFTP (SSH FTP) (v 7.0.0.54)" is loaded
I: 23.10.2017 14:58:52: Plugin "Dial-Up (v 7.0.0.134)" is loaded
I: 23.10.2017 14:58:52: Plugin "Variables (v 7.0.0.164)" is loaded
I: 23.10.2017 14:58:52: Plugin "Task Commands (v 7.0.0.147)" is loaded
I: 23.10.2017 14:58:52: Plugin "Loops And Flows (v 7.0.0.181)" is loaded
I: 23.10.2017 14:58:52: Plugin "Window (v 7.0.0.167)" is loaded
I: 23.10.2017 14:58:52: Plugin "System Events (v 7.0.0.154)" is loaded
I: 23.10.2017 14:58:52: Plugin "System Functions (v 7.0.0.158)" is loaded
I: 23.10.2017 14:58:53: Plugin "RoboTask Commands (v 7.0.0.135)" is loaded
I: 23.10.2017 14:58:53: Plugin "Clipboard (v 7.0.0.141)" is loaded
I: 23.10.2017 14:58:53: Plugin "Mouse (v 7.0.1.138)" is loaded
I: 23.10.2017 14:58:53: Plugin "Registry (v 7.0.0.127)" is loaded
I: 23.10.2017 14:58:53: Plugin "Network (v 7.0.0.130)" is loaded
I: 23.10.2017 14:58:53: Plugin "eMail (v 7.0.0.151)" is loaded
I: 23.10.2017 14:58:53: Plugin "Strings (v 7.0.0.69)" is loaded
I: 23.10.2017 14:58:53: Plugin "Web Documents (v 7.0.0.112)" is loaded
I: 23.10.2017 14:58:53: Plugin "Regular Expressions (v 7.0.0.89)" is loaded
I: 23.10.2017 14:58:53: Plugin "ScreenShot (v 7.0.0.39)" is loaded
I: 23.10.2017 14:58:53: Plugin "XML Document (v 7.0.0.27)" is loaded
I: 23.10.2017 14:58:53: Plugin "Script Tools (v 7.0.0.36)" is loaded
I: 23.10.2017 14:58:53: Plugin "Excel (v 7.0.0.17)" is loaded
I: 23.10.2017 14:58:53: Plugin "Sound Volume (v 7.0.0.7)" is loaded
I: 23.10.2017 14:58:53: Plugin "DataBase (v 7.0.0.18)" is loaded
I: 23.10.2017 14:58:53: Plugin "Basic (v 6.5.0.155)" is loaded
Also fixed small problem in Mouse plugin.
The main module (EXE file) is unchanged
Also you can check versions of plugins here:
menu Options -> Settings.
open Plugin tab
Next select necessary plugin and press About button
