Email attachments
dondada
Email attachments
Post by dondada »
Help! This should be easy...but I don't know how!
How do I use a variable to capture the file(s) in a folder and then attach that to an email?
Thanks!
Email attachments
See task below.
This task sends all files from specified folder via email. Save text of task into any file and use menu Task | Import to import into RoboTask.
Change parameters of “Send Email” action to desired
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|1374766720
ExternalName=STRING|"Task43"
ID=INTEGER|1109206663
Name=STRING|"Send Email with attachments"
caption=STRING|"Select Folder"
default=STRING|"None"
variable=STRING|"FOLD"
Name=STRING|"Create File List (c:\file_list.txt)"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
date1=STRING|"20050522"
date2=STRING|"20050522"
destfile=STRING|"c:\file_list.txt"
file0=STRING|"{fold}\*.*"
subdirs=STRING|"1"
Name=STRING|"Send Email"
attach0=STRING|"{TextFile(c:\file_list.txt)}"
attachcount=STRING|"1"
auth=STRING|"0"
from=STRING|"user@domain.com"
host=STRING|"smtp_server.com"
html=STRING|"0"
msg0=STRING|"I send you all files in folder "
msgcount=STRING|"2"
port=STRING|"25"
subject=STRING|"test"
to=STRING|"another_user@domain.com"
dondada
Email attachments
Post by dondada »
It works except for one problem. It pauses on "browse for folders" and
user action is required to continue. Please tell me how to work around
that. Thanks!
Email attachments
Turn off "Browse for folder" (or remove it) and specify folder name in "Create file list" action directly.
