SFTP wilecards
bford@vpi-i.com
SFTP wilecards
Post by bford@vpi-i.com »
I am connecting to a SFTP site and want to downoad selected files but i can not figure out the wilecards to use
The task i have setup is
1 SFTP Open
2 SFTP Download
3, SFTP Logoff
on action 2 i do not know what to put in the "Remote File or Folder:" box
can someone please advise
Brian
Re: SFTP wilecards
You have to specify file name or folder name explicitly without masks.
You can use variables, but the result should contain the name of file or folder.
If you specify file only - the action downloads only specify file
If you specify folder name - the action downloads whole folder with all files
In order to download files by mask you have to use SFTP File loop action and download all files one-by-one
Look at my example below
Next you can view it in task editor
CatID=INTEGER|1897123812
ExternalName=STRING|"Task234"
ID=INTEGER|-2039501168
Name=STRING|"download files by mask"
ActionID=STRING|"A_SFTP_LOGON"
Name=STRING|"SFTP Open (username@MyServer)"
host=STRING|"MyServer"
password=STRING|"8300183858849008361683093"
passwordmode=STRING|"0"
port=STRING|"22"
usecertificate=STRING|"0"
username=STRING|"username"
ActionID=STRING|"A_SFTP_DIR"
Name=STRING|"SFTP File loop"
date1=STRING|"18991230"
date2=STRING|"18991230"
DuringMinutes=STRING|"1"
filenameonly=STRING|"0"
folder=STRING|"./test/*.*"
kind=STRING|"0"
sizesave=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subfolders=STRING|"0"
timesave=STRING|"0"
varname=STRING|"FILENAME"
message=STRING|"Downloading {filename} "
ActionID=STRING|"A_SFTP_GET"
Name=STRING|"SFTP Download ({FileName})"
file=STRING|"{FileName}"
folder=STRING|"{TEMPDIR}"
ifexists=STRING|"1"
recursive=STRING|"0"
bford@vpi-i.com
Re: SFTP wilecards
Many thanks for the reply, i have one more silly question, how do i know thename of the folder, when i connect vit filezilla it takes me straight to the folder i have access to. i do not know the path or folder name
regards
Brian
Re: SFTP wilecards
you should know something:
- File mask
- some base folder or folders mask
you can't select folder and files interactively. You should know some parameters of files and folders.
enumerate all files from ROOT folder is a very bad idea.
BTW: sFTP File loop can make the loop by folders too.
if you don't know the name you have to use the loop to enumerate them by mask
