Triggering Events - Expression Monitor
Sokoban
Post by Sokoban »
How a task can be started when a global variable is equal to 23, for example?
I`ve been trying with this expression: {VAR} = 23, but unsuccessful.
Re: Triggering Events - Expression Monitor
Expression monitor starts the task when expression changed
Read description of this trigger
This means that any change to the expression causes the task to run.
You can check the expression value in the task.
Look at my example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
CatID=INTEGER|1040932817
ExternalName=STRING|"Task325"
ID=INTEGER|1507890890
Name=STRING|"Expression monitor (when MyVar=23)"
value1=STRING|"{MyVar}"
value2=STRING|"23"
msg1=STRING|"Hey, awake!"
msgcount=STRING|"2"
EventID=STRING|"E_VARIABLES_MONITOR"
Name=STRING|"Expression Monitor"
UniqueID=INTEGER|-410623771
id=STRING|"BA9NSBZM"
line00000000=STRING|"{MyVar}"
Sokoban
Post by Sokoban »
Log returns "The task contains UNKNOWNS steps.".
I`m running Lite version 7.0.1.932
Unfortunately loops and flow control are not available in the lite version.
