Uninstall
joezimm
Uninstall
Post by joezimm »
We tried Robo Task on one of our servers and the eval has expired. There is no routine to uninstall. How does this software uninstall?
THX
Uninstall
Start | Programs | RoboTask | Uninstall Robotask
Also you can use "Add remove programs" in control panel
joezimm
Uninstall
Post by joezimm »
There isn't a start\programs\robotask\uninstall robotask.
Also there is no robotask in add remove programs.
What I was left with is an annoying pop up that said the eval expired and a service I had to disable because the software doesn't have an uninstall.
I removed the run feature from the registry so i don't get the pop up and set the service to "disabled" until I can go back through the registry and manually pick and clean this software off the server.
THX
