What is new in version 2.3?
David.Marsh
Post by David.Marsh »
What are the new features and fixes in version 2.3?
New:
   New action "Wait for file".
   Added possibility to enumerate folders into "File loop" and "Search for files" actions.
   New actions: "Import registry" and "Export Registry"
Fixed:
   Fixed expanding text bug when complex parameter with nested variables is used.
   Fixed break bug in nested loops.
... and other small improves and bugfixes
waldo
Post by waldo »
I have registered version 2.2.1 currently installed on my PC.  Do I need to uninstall this version prior to upgrading to version 2.3?  If so, I assume the original purchase code is still valid to activate version 2.3?  Finally, do I need to re-install the 3 plug-ins (basic, cd writer, icq) once I upgrade to version 2.3 or will version 2.3 recognize that I already have these add-ins installed?  THANKS.
You can install RoboTask 2.3 over old version. Just stop RoboTask (and RoboTask service too) before installation. Your registration code is valid for version 2.3 too.
No. Reinstallation of additional plugins doesn't require.
waldo
Post by waldo »
Oleg,
Thanks for the additional information on the install of version 2.3.  Take care.
