Trouble with Excel Get Cells
merka
Post by merka »
Hi.
I can't figure out how to extract contents of an Excel cell and add it to a variable.
I am doing the following steps,
1. Excel Open Document
2. Excel Get Cells - I added the cell reference and created GLobal and Local variables (I called it {NAME} because the contents of the cell will be a name) but can't get them to work.
I get the errors below,
Invalid variable name
Variable name is empty
Any suggestions as to what I may be doing wrong?
Thanks, Brett.
Re: Trouble with Excel Get Cells
look at this example how to get cells to variables
CatID=INTEGER|2091586075
ExternalName=STRING|"Task1105"
ID=INTEGER|-12526969
Name=STRING|"Get from cells to variables"
filename=STRING|"D:\Temp\test.xls"
hide=STRING|"1"
mode=STRING|"0"
tryconnect=STRING|"0"
ActionID=STRING|"A_EXCEL_GET"
Name=STRING|"Excel Get Cells"
cell00000000=STRING|"c4"
cell00000001=STRING|"c5"
cell00000002=STRING|"c6"
cell00000003=STRING|"c7"
cell00000004=STRING|"c8"
cell00000005=STRING|"c9"
cell00000006=STRING|"c10"
count=STRING|"7"
var00000000=STRING|"var1"
var00000001=STRING|"var2"
var00000002=STRING|"var3"
var00000003=STRING|"var4"
var00000004=STRING|"var5"
var00000005=STRING|"var6"
var00000006=STRING|"var7"
worksheet=STRING|"1"
Name=STRING|"Show ""cell values are:"""
msg0=STRING|"cell values are:"
msg1=STRING|"c4 = {var1}"
msg2=STRING|"c5 = {var2}"
msg3=STRING|"c6 = {var3}"
msg4=STRING|"c7 = {var4}"
msg5=STRING|"c8 = {var5}"
msg6=STRING|"c9 = {var6}"
msg7=STRING|"c10 = {var7}"
msgcount=STRING|"8"
Then you can see the task in task editor and edit it.
This example shows how to put some values to Excel document
ExternalName=STRING|"Task189"
ID=INTEGER|1436022166
Name=STRING|"Put data from text to Excel document"
Name=STRING|"Set variable ""exceldoc"" with value ""D:\temp\test.xls"""
varname=STRING|"exceldoc"
varvalue=STRING|"D:\temp\test.xls"
Name=STRING|"Show ""Done!"""
msg0=STRING|"Done!"
msg1=STRING|"Click OK to view result!"
msgcount=STRING|"2"
Name=STRING|"Run ""{ExcelDoc} """
ifnonzero=STRING|"0"
program=STRING|"{ExcelDoc}"
runas=STRING|"0"
wait=STRING|"0"
filename=STRING|"{ExcelDoc}"
hide=STRING|"0"
mode=STRING|"0"
Name=STRING|"Set variable ""NUM"" with value ""1"""
varname=STRING|"NUM"
varvalue=STRING|"1"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"This is"
line1=STRING|"simple text "
line2=STRING|"to copy "
line3=STRING|"it to "
line4=STRING|"Excel document"
linecount=STRING|"5"
sourcetext=STRING|"1"
ActionID=STRING|"A_EXCEL_SET"
Name=STRING|"Excel Set Cells"
cell00000000=STRING|"R{num}C1"
setmode=STRING|"0"
var00000000=STRING|"{line}"
worksheet=STRING|"2"
incement=STRING|"1"
vaiable=STRING|"num"
ActionID=STRING|"A_EXCEL_SAVEDOC"
Name=STRING|"Excel Save Document"
ActionID=STRING|"A_EXCEL_CLOSE"
Name=STRING|"Excel Close"
