Set Current Folder PRoblem
FourthPress
Post by FourthPress »
Having a problem with Set Current Folder. I am trying to move or copy selected files from one folder to another and the Set Current Folder doesnt't change to the specified folder and the macro simply creates a copy in the original folder. In the prior version of Robotask this macro worked fine. Using Windows 10 with Robotask current version
Re: Set Current Folder PRoblem
Could you send the problem task?
Or some simple example with same problem.
FourthPress
item0000=STRINGLIST
item0001=STRINGLIST
item0002=STRINGLIST
[\item0000]
s1=[General]
s2=ActionId=A_CLIPBOARD_COPY
s3=Name=Copy
s4=Enabled=-1
s5=[Params]
s6=mode=1
[\item0001]
s1=[General]
s2=ActionId=A_FOLDER_CHANGE
s3=Name=Set Current Folder (C:\Users\FSP\Desktop\3100 Print Color\3100 Color Letter Print\Print To Letter 20# Color)
s4=Enabled=-1
s5=[Params]
s6=folder="C:\Users\FSP\Desktop\3100 Print Color\3100 Color Letter Print\Print To Letter 20# Color"
[\item0002]
s1=[General]
s2=ActionId=A_CLIPBOARD_PASTE
s3=Name=Paste
s4=Enabled=-1
s5=[Params]
s6=mode=1
Set current folder action changes the folder for RoboTask process only. Not for Windows Explorer or for system or other Windows Application.
The problem is that every Windows application can have its own current folder.
So this step has no sense in context of your task.
Look at the corrected below
Now you can select necessary files in Windows Explorer and press CTRL+SHIFT+ALT+C to run the task.
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1179"
ID=INTEGER|352642803
Name=STRING|"Copy...(corrected 2)"
Name=STRING|"Copy"
mode=STRING|"1"
Name=STRING|"Delay 2 sec"
delay=STRING|"2"
dimension=STRING|"1"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"C:\IMPRESSIA #10"
f_count=STRING|"1"
file0=STRING|"{ClipBoardContent}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"0"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"1"
Name=STRING|"Shift+Ctrl+Alt+C"
UniqueID=INTEGER|1909073996
hotkey=STRING|"57411"
