Basic plugin error in update?
rpmain84
Post by rpmain84 »
Hello, I updated to 8.3.3.1047 and the internal basic script tasks I have no longer work. I tried reinstalling the plugin from the download page and I am still getting an error
E: 6/30/2021 9:57:39 AM: Catastrophic failure
E: 6/30/2021 9:57:39 AM: Failed execute 'ExecAction with exception: Catastrophic failure' (C:\Program Files (x86)\RoboTask\Plugins\Basic\Basic.rtp)
E: 6/30/2021 9:57:39 AM: An error occurred. Reconfigure this step.
I made sure the plug in is configured to point to this folder as well. Any suggestions for how I can fix this?
Re: Basic plugin error in update?
send me your task to oleg@robotask.com. Export the task to a file and send it to me.
I will try to fix it.
Basic plugin is deprecated. It's strongly recommended to migrate the action to VB Script
I can try to help you to do this
rpmain84
Post by rpmain84 »
Ok thank you, sending to you now
