Runing a task outside of robotask
eranz
Post by eranz »
I have a table of items in sql server.
I want to give the ability for a user to delete an entry (an item) from the table.
I can create a task that runs a sql query to delete the requested item from the table.
How can I give the ability for the user to run this task without opening the robotask and edit the item id in the sql query.
Can I create some kind of gui?
Or can he send a mail to some email address with the subject 81 for example, the task will monitor this mail once an hour, take this parameter and delete item 81 from the items table?
Thanks,
Eran
Re: Runing a task outside of robotask
You can use parametrized SQL query. You can read necessary values from Input Dialog or from text file (as you wish)
Look at my example below
CatID=INTEGER|1163085779
ExternalName=STRING|"Task142"
ID=INTEGER|474830898
Name=STRING|"delete specified record"
Name=STRING|"Input Box"
default=STRING|"0"
password=STRING|"0"
prompt=STRING|"Enter ID of record to delete"
variable=STRING|"RECORDID"
operator=STRING|"1"
type=STRING|"1"
value1=STRING|"{RecordID}"
value2=STRING|"0"
ActionID=STRING|"A_EXECSQL"
Name=STRING|"SQL Query"
assignvar=STRING|"1"
connectionstring=STRING|"Provider=MSDASQL.1;Persist Security Info=False;Data Source=MySQLTest"
override=STRING|"0"
paramcount=STRING|"1"
password=STRING|"2159219849198532138421648"
pname0=STRING|"param1"
ptype0=STRING|"1"
pvalue0=STRING|"{RecordID}"
sql=STRING|"""delete from testtable where id = :param1"""
timeout=STRING|"60"
varname=STRING|"num"
colorscheme=STRING|"0"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
icon=STRING|"3"
kind=STRING|"0"
message=STRING|"{num} records deleted"
position=STRING|"3"
title=STRING|"Delete record "
width=STRING|"330"
