Start-up Error Messages ver 2.4 upgrade
waldo
Post by waldo »
I updated to version 2.4 from 2.3.  I also restarted my computer [Xp Pro Sp 1].  Now when robotask starts I get the following error messages:
E: 2/12/2006 8:43:14 PM: Bad action ID "A_GENERAL_RUN_PROG" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad action ID "A_GENERAL_PRINTDOC" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad action ID "A_GENERAL_SENDKEYS" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad action ID "A_GENERAL_LOGOFF" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad action ID "A_GENERAL_PAUSE" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad action ID "A_EXECSQL" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad action ID "A_WAITFORPROCESS" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad event ID "E_GENERAL_SHEDULER" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad event ID "E_GENERAL_HOTKEY" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad event ID "E_GENERAL_TRAYICON" in plugin "General"
E: 2/12/2006 8:43:14 PM: Bad event ID "E_GENERAL_CYCLIC" in plugin "General"
There were no error messages on start-up with version 2.3.  There have been no other changes to my system configuration.  Any ideas how to correct these error messages?  THANKS.
I think that you have renamed General plugin in old version. Original file name is Miscellaneous.rtp. Usually it is in Plugins\Misc subfolder.
Try to do the following:
1. Stop RoboTask (and service too, if it started)
2. Remove Plugins folder manually. Usually it is "C:\Program Files\RoboTask\Plugins\"
3. Reinstall RoboTask
4. Start RoboTask again
waldo
Post by waldo »
Oleg,
I think that you are correct.  I remember that you sent me a new module via e-mail as I discovered a problem with using the scheduler on the last day of the month [ i.e., events did not work if scheduled on the last day of the month].  I guess I need to ensure that version 2.4 has this correction in it as I have 22 robotasks that run on the last day of each month.  Do you happen to remember if the last day of month scheduler error was fixed in either ver 2.3 or ver 2.4?  THANKS.
This bug has been fixed. Corrected plugin was included into 2.3 version.
waldo
Post by waldo »
Oleg,
Thanks for the advice...removing the plug-in folder and re-installing RoboTask solved my issue.  Again, thank you.
