Frequent Evaluate error
steph@vds
Post by steph@vds »
Hi Oleg,
I often have strange evaluate error in tasks like this one below.
This task is used to propose the user to create a file with an amount of Mo or Go.
My evaluate expressions are simple multiplications between a constant and a previously entered variables.
I use evaluate expressions instead of basic script because it's too much hard for me to program basic scripts.
Thanks in advance.
Steph@vds.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|111458465
ExternalName=STRING|"Task267"
ID=INTEGER|1145916002
Name=STRING|"CREER UN FICHIER D'UNE TAILLE DONNEE"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Action26=FOLDER
Action27=FOLDER
Action28=FOLDER
Action29=FOLDER
Action30=FOLDER
Action31=FOLDER
Action32=FOLDER
Name=STRING|"Start Task ""CAPSLOCK"""
taskid=STRING|"1763296260"
wait=STRING|"1"
value1=STRING|"{FileExists({folder}{FICHIER})}"
ActionID=STRING|"A_DIALOG_QUESTION"
Name=STRING|"Question Dialog"
abortif=STRING|"0"
action=STRING|"1"
autotime=STRING|"0"
buttons=STRING|"1"
message=STRING|"""Le fichier existe déjà, tu veux l'effacer ?"""
time=STRING|"60"
variable=STRING|"EFFACE"
[Actions\Action12\Params]
value1=STRING|"{EFFACE}"
Name=STRING|"Delete File"
[Actions\Action13\Params]
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{folder}{FICHIER}"
subdir=STRING|"0"
ToRecycleBin=STRING|"1"
[Actions\Action14]
[Actions\Action15]
[Actions\Action16]
[Actions\Action16\Params]
value1=STRING|"{TYPETAILLE}"
[Actions\Action17]
Name=STRING|"Evaluate en Mo"
[Actions\Action17\Params]
expression=STRING|"1048576*{TAILLEMO}"
variable=STRING|"TAILLEDEF"
[Actions\Action18]
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
[Actions\Action19]
Name=STRING|"Evaluate en Go"
[Actions\Action19\Params]
expression=STRING|"1073741824*{TAILLEGO}"
caption=STRING|"Où veux-tu créer ton fichier ?"
default=STRING|"None"
folder=STRING|"F:\"
variable=STRING|"FOLDER"
[Actions\Action20]
[Actions\Action21]
Name=STRING|"Run ""cmd.exe"""
[Actions\Action21\Params]
program=STRING|"C:\WINDOWS\system32\cmd.exe"
runas=STRING|"0"
wait=STRING|"1"
[Actions\Action22]
Name=STRING|"fsutil file createnew {folder}\{fichier} {TAILLEDEF}"
[Actions\Action22\Params]
currentwindow=STRING|"1"
fixedwindow=STRING|"1"
keylayout=STRING|"0"
keys=STRING|"""fsutil file createnew {folder}\{fichier} {TAILLEDEF}"""
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
[Actions\Action23]
Name=STRING|"{ENTER}"
[Actions\Action23\Params]
keys=STRING|"{ENTER}"
sendkind=STRING|"0"
[Actions\Action24]
Name=STRING|"Delay 2000 ms"
[Actions\Action24\Params]
delay=STRING|"20"
[Actions\Action25]
Name=STRING|"exit{ENTER}"
[Actions\Action25\Params]
keys=STRING|"exit{ENTER}"
sendkind=STRING|"0"
[Actions\Action26]
Name=STRING|"Remove variable ""EFFACE"""
[Actions\Action26\Params]
varname=STRING|"EFFACE"
[Actions\Action27]
Name=STRING|"Remove variable ""FOLDER"""
[Actions\Action27\Params]
varname=STRING|"FOLDER"
[Actions\Action28]
Enabled=INTEGER|0
Name=STRING|"Remove variable ""TAILLEDEF"""
[Actions\Action28\Params]
varname=STRING|"TAILLEDEF"
[Actions\Action29]
Enabled=INTEGER|0
Name=STRING|"Remove variable ""TAILLEMO"""
[Actions\Action29\Params]
varname=STRING|"TAILLEMO"
Name=STRING|"Question Dialog TYPETAILLE"
abortif=STRING|"0"
action=STRING|"1"
autotime=STRING|"0"
buttons=STRING|"1"
message=STRING|"""Tu veux entrer une taille en Mo ou en Go ?"",""Mo = YES"",""Go = NO"""
time=STRING|"60"
variable=STRING|"TYPETAILLE"
[Actions\Action30]
Enabled=INTEGER|0
Name=STRING|"Remove variable ""TAILLEGO"""
[Actions\Action30\Params]
varname=STRING|"TAILLEGO"
[Actions\Action31]
Enabled=INTEGER|0
Name=STRING|"Remove variable ""TYPETAILLE"""
[Actions\Action31\Params]
varname=STRING|"TYPETAILLE"
[Actions\Action32]
Name=STRING|"Remove variable ""FICHIER"""
[Actions\Action32\Params]
varname=STRING|"FICHIER"
Name=STRING|"Input Box TAILLE Mo"
default=STRING|"0"
prompt=STRING|"Quelle taille (en Mo) ?"
variable=STRING|"TAILLEMO"
Name=STRING|"Else"
Name=STRING|"Input Box TAILLEGO"
default=STRING|"0"
prompt=STRING|"Quelle taille (en Go) ?"
variable=STRING|"TAILLEGO"
Name=STRING|"Input Box FICHIER"
default=STRING|"none"
prompt=STRING|"Quel nom de fichier ?"
variable=STRING|"FICHIER"
I think thet you use very large values. Maybe Basic engine determines these values as interger. But integer value have restriction from -2147483648 to +2147483647 only
Try to write
1048576.0*{TAILLEMO}
1073741824.0*{TAILLEGO}
instead of
1048576*{TAILLEMO}
You tell basic engine that values are real. Real values have more large diapason.
Also you can write
1048576#*{TAILLEMO}
1073741824#*{TAILLEGO}
