Variable assignment critical error
BrianSmith
Post by BrianSmith »
I have created a FileLoop action and assigned the modified time of each file in the loop to a variable CURRENT_DATETIME.
Outside the loop I create a variable LATEST_DATETIME = 01/01/1890 12:00:00 that gets set inside the loop to the CURRENT_DATETIME variable only if the CURRENT_DATETIME variable is greater then the LATEST_DATETIME variable.
This task is to find the latest/newest file in a folder by the way.
When the If statement is true I "Set Variable" LATEST_DATETIME = "{CURRENT_DATETIME}"
This works the first time the If statement is true which in most cases will always be the first file, but after that each time the FileLoop grabs another file and sets the CURRENT_DATETIME, LATEST_DATETIME automatically gets set to the value of CURRENT_DATETIME as the If statement has assigned the LATEST_DATETIME variable to be {CURRENT_DATETIME} as a string.
This causes the If statement to never execute again and the LATEST_DATETIME variable to always take on the CURRENT_DATETIME of the current file so I end up with the LATEST_DATETIME variable holding the modified date of the last file in the folder.
How do I stop the variable assignment of LATEST_DATETIME from taking on the string "{CURRENT_DATETIME}" and not just the date/time value of this variable.
I have included the RoboTask for you to test.
; RoboTask Task file
; Do not edit!
CatID=INTEGER|802282160
ExternalName=STRING|"Task7"
ID=INTEGER|782740870
Name=STRING|"Find the latest/newest modified file in a folder."
Name=STRING|"Create variable ""LATEST_DATETIME"" with value ""01/01/1890 12:00:00"""
varname=STRING|"LATEST_DATETIME"
varvalue=STRING|"01/01/1890 12:00:00"
Name=STRING|"Show ""The latest file is ({LATEST_FILENAME}) modified {LATEST_DATETIME}."""
msg0=STRING|"The latest file is ({LATEST_FILENAME}) modified {LATEST_DATETIME}."
msg2=STRING|"You can now add another action to this task to copy this file wherever you like."
msgcount=STRING|"3"
Name=STRING|"File Loop"
date1=STRING|"20040520"
date2=STRING|"20040520"
destvar=STRING|"CURRENT_FILENAME"
file0=STRING|"{TEMPDIR}\*.*"
subdirs=STRING|"1"
timesize=STRING|"1"
timevar=STRING|"CURRENT_DATETIME"
WithoutPath=STRING|"1"
message=STRING|"{CURRENT_DATETIME}"
message=STRING|"{LATEST_DATETIME}"
operator=STRING|"3"
type=STRING|"2"
value1=STRING|"{CURRENT_DATETIME}"
value2=STRING|"{LATEST_DATETIME}"
message=STRING|"CURRENT_DATETIME {CURRENT_DATETIME} > LATEST_DATETIME {LATEST_DATETIME}"
Name=STRING|"Set variable ""LATEST_FILENAME"" with value ""{CURRENT_FILENAME}"""
varname=STRING|"LATEST_FILENAME"
varvalue=STRING|"{CURRENT_FILENAME}"
Name=STRING|"Set variable ""LATEST_DATETIME"" with value ""{CURRENT_DATETIME}"""
varvalue=STRING|"{CURRENT_DATETIME}"
AlexeySurkis
Post by AlexeySurkis »
In the Set Variable action, we've added the "Expand Variable Value" option. Please wait for the new version 2.1. Thank you for your patience.
