Working with variables
hendrix666
Post by hendrix666 »
Hi everyone!!
Is it possible to pass some variable from other application to RoboTask via Visual Basic(e.g. a MS Access form), instead of using the clipboard or an array text file?
I have to pass some variables from an active form in Access to put them on another application.
Thx a lot!
Yes of course.
see sample code below
    Dim o As Object
    Set o = CreateObject("RoboTask.app")
    o.SetUserVariable "ExcelValue", "12345"
    Set o = Nothing
For more infomation about COM object of RoboTask see help file, topic "Actions -> Basic -> RoboTaskApp object"
hendrix666
Thx, it's working perfectly this way. I have one more doubt, is there a way to wait for a task finished in a visual basic script? I need to have the task finished in order to retrieve the variables to an Acces form. Thanks again!!
Hmm...
RoboTask haven't function for detection the state of task from within basic script directly. Maybe we have to add this.
Now you can do the following:
add into the task some flag-variable. In the beginning of the task set it to value 1 (for example) and before ending set to 0
In the basic script you can do this
   Dim o As Object
   o.StartTask "MyTask"
   While o.ExpandText("{FlagVar}") = "1"
      Wait 0.5
   Wend
   'Do something
   Set o = Nothing
Naras
Re: Working with variables
Post by Naras »
Is it possible to pass a variable from a php script to Robotask?
I have a script that processes email based on the type. Depending on the type will determine which email is sent.
See my example for PHP script:
CatID=INTEGER|317955339
ExternalName=STRING|"Task846"
ID=INTEGER|468118999
Name=STRING|"Variable from PHP"
Name=STRING|"Create global variable ""MYVAR"" with value ""nothing"""
varkind=STRING|"0"
varname=STRING|"MYVAR"
varvalue=STRING|"nothing"
Name=STRING|"Show ""Before script MyVar is"""
msg0=STRING|"Before script MyVar is"
msg2=STRING|"{MyVar}"
msg4=STRING|"Press OK to start PHP script"
msgcount=STRING|"5"
Name=STRING|"Run ""php.exe D:\Temp\testscript.php"""
ifnonzero=STRING|"0"
params=STRING|"D:\Temp\testscript.php"
program=STRING|"C:\Program Files (x86)\PHP\v5.3\php.exe"
runas=STRING|"0"
wait=STRING|"2"
Name=STRING|"Show ""After script MyVar is"""
msg0=STRING|"After script MyVar is"
msgcount=STRING|"3"
I use script testscript.php
<?php
$RT = new COM("RoboTask.App");
//echo $RT->Version;
$RT->SetUserVariable("MyVar", "Hello World!!!");
