file sizes
sen5243
file sizes
Post by sen5243 »
Hi Oleg
I’ve got a question.
I have three folders, they are called 01,02 and 03.
All three folders contain the same file called: test.xml.
But their file sizes are different.
Now I need the middle sized file, in one of these folders.
And then move the file to a different location.
Is it possible to help me?
Thanks Richard
file sizes
There is {FileSize()} system variable
You may use it:
{FileSize(c:\01\test.xml)}
{FileSize(c:\02\test.xml)}
{FileSize(c:\03\test.xml)}
In order to determine the miidle size use the following algorithm:
Suppose we have 3 values: size1, size2, and size3
if size1 > size2 then
   if size1 < size3 then
      middle = size1
   else
      if size2 > size3 then
         middle = size2
      else
         middle = size3
      end if
   end if
else
   if size1 > size3 then
      middle = size1
   else
      if size2 < size3 then
         middle = size2
      else
         middle = size3
      end if
   end if
end if
sen5243
file sizes
Post by sen5243 »
Hi oleg
It is working flawless !!
Thanks a lot
richard
