Size limitation of ZIP task
gootchick
Post by gootchick »
What is the size limitation of ZIP task ? I used 7-zip program for zip operation until now. When I read about new ZIP engine with ability compress files bigger than 2GB, I made upgrade. But I have still problem with compression bigger files. When I try compress file with size over 6GB, I get message Error 1030 Warning: XXX is too long.
(maybe the limit is 4GB, but my file system is NTFS).
We'll investigate the problem.
But now I advise you to use external archiver with command-line for this purpose.
