reserved symbol "."
ragnusapiens
reserved symbol "."
Post by ragnusapiens »
How can i insert a dot in a "send keys to active window" command?
reserved symbol "."
Just put dot symbol into "Keys" field.
I've just tried it's working...
ragnusapiens
reserved symbol "."
Oleg wrote:Just put dot symbol into "Keys" field.
i'm italian and i'm using an european keyboard, so i put dot and comes out a comma ","
any suggestion?
ragnusapiens
reserved symbol "."
any suggestion?
after some tests i noticed that the problem occurs only if i type the period "." in an excel cell
