Auto deleting.
gumby69
Auto deleting.
Post by gumby69 »
i need to delete files in a folder only older than 24 hours i'm new to this can anyone tell me how to do it? It would be much appreciated. Thank You
Auto deleting.
See the example below. I think you can change this task for your purposes. Also you can attach cyclic event to the task, for example each 900 s (15 min)
CatID=INTEGER|1146669232
ExternalName=STRING|"Task18"
ID=INTEGER|2005651541
LocalVariables=STRING|"c_file,c_date"
Name=STRING|"Detect files older than 24 hours"
ToLog=INTEGER|2
Name=STRING|"File Loop"
date1=STRING|"20091211"
date2=STRING|"20091211"
destvar=STRING|"C_FILE"
file0=STRING|"{TempDir}\*.*"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"1"
timevar=STRING|"C_DATE"
Name=STRING|"Evaluate"
expression=STRING|"datediff(""h"",cdate(""{c_date}""), now())"
variable=STRING|"DIFF"
operator=STRING|"2"
type=STRING|"1"
value1=STRING|"{diff}"
value2=STRING|"24"
message=STRING|"File {c_file} older than 24 hours ({diff} hours)"
gumby69
Auto deleting.
Post by gumby69 »
Thanks Oleg much appreciated.
